Re: [N8VEM: 14608] Re: ParPortProp Terminal Emulation
Total of 6 are normally in use:
1 for Main
1 for Keyboard
2 for VGA
1 for Serial Port
1 for SD Card
-Wayne
On Sunday, September 9, 2012 6:51:53 PM UTC-7, J. Alexander Jacocks wrote:
How many cogs are in use, with the current ParPortProp firmware?
- Alex
On Sun, Sep 9, 2012 at 3:35 PM, Wayne Warthen <wwa...@gmail.com> wrote:
> Yeah, that is all I found as well.  There is a tile driver that should be
> able to do it, but requires 4 cogs and a 1280x1024 screen resolution.  I was
> reluctant to go down that path.
> James, if you know of a driver that is appropriate, I would definitely be
> interested.
> Thanks,
> Wayne
> On Sunday, September 9, 2012 11:53:27 AM UTC-7, yoda wrote:
>> Hi James
>> I don't recall seeing anything that will drive 80x30+ characters with
>> single character color attributes - I think there are some with lower
>> character displays but not much user for a real terminal application.
>> Dave
>> On Sunday, September 9, 2012 8:17:45 AM UTC-5, James Moxham (Dr_Acula)
>> wrote:
>>> I believe there is a new video driver on the propeller forum that can do
>>> individual character colors if you want to. I've not used it, but it can be
>>> done now.
>>> Cheers, James Moxham
>>> On 9/09/2012 1:50 PM, Wayne Warthen wrote:
>>> Hi Alex,
>>> The ParPortProp implements a reasonable subset of ANSI terminal
>>> emulation.  However, it is not capable of setting individual character
>>> colors.  The Propeller video driver, in it's current state, only allows
>>> color to be set for an entire line, which is not very useful for terminal
>>> emulation.  As you can see, it is used to change the color of the
>>> "information" line, but there is no mechanism for setting character colors
>>> as you might expect using ANSI escape sequences.
>>> Thanks,
>>> Wayne
>>> On Saturday, September 8, 2012 8:28:43 PM UTC-7, Alexander wrote:
>>>> I've been happy as a clam with the ParPortProp expansion board.  I've
>>>> recently been fooling around with a lot of software from the Humongous CP/M
>>>> Software Archive (http://www.classiccmp.org/cpmarchives/), and I started to
>>>> wonder what terminal emulation the VGA console does.  I do see on the
>>>> description that it does 64 colors, but I haven't a clue how to make use of
>>>> them.
>>>> Any suggestions?
>>>> Thanks!
>>>> - Alex
>>> You received this message because you are subscribed to the Google Groups
>>> "N8VEM" group.
>>> To view this discussion on the web visit
>>> https://groups.google.com/d/msg/n8vem/-/MzzbKXOOB4AJ.
>>> To post to this group, send email to n8...@googlegroups.com.
>>> To unsubscribe from this group, send email to
>>> n8vem...@googlegroups.com.
>>> For more options, visit this group at
>>> http://groups.google.com/group/n8vem?hl=en.
> "N8VEM" group.
> https://groups.google.com/d/msg/n8vem/-/izHGbDXaSFMJ.
> n8vem+un...@googlegroups.com.
