Re: [N8VEM: 14588] Re: ParPortProp Terminal Emulation
Yeah, that is all I found as well.  There is a tile driver that should be able to do it, but requires 4 cogs and a 1280x1024 screen resolution.  I was reluctant to go down that path.
James, if you know of a driver that is appropriate, I would definitely be interested.
Wayne
On Sunday, September 9, 2012 11:53:27 AM UTC-7, yoda wrote:
Hi James
I don't recall seeing anything that will drive 80x30+ characters with single character color attributes - I think there are some with lower character displays but not much user for a real terminal application.
Dave
On Sunday, September 9, 2012 8:17:45 AM UTC-5, James Moxham (Dr_Acula) wrote:
I believe there is a new video driver on the propeller forum that can do individual character colors if you want to. I've not used it, but it can be done now.
Cheers, James Moxham
On 9/09/2012 1:50 PM, Wayne Warthen wrote:
Hi Alex,
The ParPortProp implements a reasonable subset of ANSI terminal emulation.  However, it is not capable of setting individual character colors.  The Propeller video driver, in it's current state, only allows color to be set for an entire line, which is not very useful for terminal emulation.  As you can see, it is used to change the color of the "information" line, but there is no mechanism for setting character colors as you might expect using ANSI escape sequences.
Wayne
On Saturday, September 8, 2012 8:28:43 PM UTC-7, Alexander wrote:
I've been happy as a clam with the ParPortProp expansion board.  I've recently been fooling around with a lot of software from the Humongous CP/M Software Archive (http://www.classiccmp.org/cpmarchives/), and I started to wonder what terminal emulation the VGA console does.  I do see on the description that it does 64 colors, but I haven't a clue how to make use of them.
Any suggestions?
Thanks!
- Alex
To view this discussion on the web visit https://groups.google.com/d/msg/n8vem/-/MzzbKXOOB4AJ.
To unsubscribe from this group, send email to n8vem...@googlegroups.com.
