On 09/09/2012 09:41 AM, Wolfgang Kabatzke wrote:
Am 09.09.2012 17:42, schrieb John
Coffman:
On 09/08/2012 11:50 PM, Sergey wrote:
It must be some kind of conspiracy about switch debouncing, it looks
like 90% of the related pages on the Internet are referring to this
"research": http://www.ganssle.com/debouncing-pt2.htm . More exactly
to the circuit on Figure 3 (the circuit on Figure 1, which also
frequently referred everywhere, is mostly unusable, since nobody will
use a double throw switch just to overcome the contact bounce)
Simpler even than the circuit shown in Fig. 1 (see above) is the
attached circuit. Although it breaks all the rules about
shorting a gate output to GND, it operates well within the specs
for LS-TTL. Further, it minimizes components: only an SPDT
switch and a cheap IC are used.
The LS-TTL spec states that LS must not be harmed by a short
circuit to power or ground of duration less than 1 second. This
circuit shorts the output of a gate to ground for no more than
10ns, within the spec by a factor of 100,000.
In engineering a debounce circuit, using the absolute minimum of
components is generally the most economical approach. The LS00
solution of Fig. 1 above is good (the resistors to +5 can
actually be eliminated with LS-TTL), but the attached circuit is
even simpler.
I know of no more economical solution.
You received this message because you are subscribed to the
Google Groups "N8VEM" group.
Hello John,
Sergeys circuit is absolute correct. Your circuit never works
correct. I watched my textbook about TTL-IC and there is Your
circuit out of standard.
Totally not true. This circuit WORKS!!! And I know of no simpler
solution to switch de-bounce.
