RE: [N8VEM: 2399] Re: Photos of the N8VEM Disk IO Board
Hi Joe! Thanks! The SIP resistor packs are bussed with pin 1 being common.
The SIP resistor packs are the 9 pin variety which sometimes are hard to
find but you can use the 10 pin SIPs as well. You just trim off pin 10 so
it does not contact the board and it looks and works just fine. I did that
trick myself when I couldn't find the 9 pin SIPs.
I know they are out there someplace since I have used them before but I
suppose they are getting obsolete or something. From now on, I am using 10
pin SIPs in the resistor packs.
Thanks and have a nice day!
Andrew Lynch
> -----Original Message-----
> joebandit
> Sent: Tuesday, February 03, 2009 7:31 PM
> To: N8VEM
> Subject: [N8VEM: 2399] Re: Photos of the N8VEM Disk IO Board
> The SIP packs, bussed or isolated?
> On Feb 3, 3:14 am, HD64180 <Harrma...@t-online.de> wrote:
> > Hello Andrew,
> > On 3 Feb., 01:36, "Andrew Lynch" <lyn...@yahoo.com> wrote:
> > > Hi Rolf! Thanks! Those are great pictures of the Disk IO board!
> > > On a related note, has anyone tried the Disk IO IDE interface? If so,
> what
> > > happened?
> > > If it were me, I would start with the RAM monitor and see if you can
> get the
> > > IDE registers to respond and then try with the IDE test code. If that
> > > works, try the IDE CBIOS.
> > i have uploaded a new of the N8VEM Disk IO Board.
> > http://www.hd64180-ecb.de/html/board5.html
> > http://www.hd64180-ecb.de/assets/images/N8VEM_Disk_IO_Boardw09.jpg
> > I had forgotten the 74LS164 or 74HCT164 Parts order will probably
> > arrive today.
> > I have this Day the Parts 8272A and FDC9229BT arrive from Seller.
> > http://www.littlediode.com/components/home.php
> > Thank you!
> > Have a nice day!
> > Rolf
