Correction to CUBIX command LDIR.asm
Code as from Dan's zip
        FCC     ' directories.'
        FCB     00      CLRA                    ZERO RETURN CODE
        FCB     00
ABORT   SWI
        FCB     0               BACK OFF
This causes the command not to set a return code and never end.
My assumption is that it branches back to location zero and starts
running over and over and over again.
Correction to LDIR source
        FCC     ' directories.'
        FCB     00
ABORT   SWI
        FCB     0               BACK OFF
I discovered the difference after doing a diff between the source code from the CUBIX web site repository against Dan's code.
His changes were necessary  to use the a09 cross assembler.  The return back to CUBIX via a SSR macro got mangled.
Aug
