Re: ECB PropTerm
Why do we need another propIO which this is with a parallel port stuck in front of it? PropIO works reliably under 6MHz and can be made reliable above that by just putting in a set/reset flipflop of the CS / enable connect to the wait. I believe there are spare NAND gates on the board to do this but I have not had time to do that - seems it would be more productive to implement the solution on the current board and get a re spin then to make a whole new board.
On Tuesday, February 12, 2013 2:37:16 AM UTC-6, Sergey wrote:Hi,
I uploaded the initial schematics for ECB PropTerm:
http://n8vem-sbc.pbworks.com/w/file/63550295/ECB%20PropTerm%20-%20Schematic%20-%200.1.pdf
Basically it is a ParPortProp together with an 8255 PPI and ECB
interface attached.
It provides simple and reliable terminal (and also SD card storage)
capabilities to ECB systems.
Perhaps schematic can be simplified a bit (I think 74LS241 buffers on
EBC are redundant).
I'd like to get any comments and suggestions...
Sergey
