Re: [N8VEM: 15575] Re: SBC v2 Not running
Also try pressing the reset button after power up,
Cheers!
On Wed, Feb 13, 2013 at 7:02 AM, Sergey <skis...@gmail.com> wrote:
I'd recommend getting a high-resolution pictures of your board (both
front and back sides) and posting them here. Perhaps someone could
spot the problem.
Other than that check simple things first - make sure you have 5V on
ICs (and it is really 5V, or very close to it). Check your soldering.
Double check component orientation (ICs, diodes). Check that your
serial terminal is set to the correct baud rate (if I am not mistaken
38400 bps / 8 bit / no parity / 1 stop bit / no flow control). Check
the wiring of your serial cable. It should be a null-modem cable (RX/
TX swapped) if you're using your PC as a terminal.
Next it all depends on the diagnostic tools you have...
Sergey
On Feb 12, 11:54 am, Martin Boháč <bohacm...@gmail.com> wrote:
> Hi !
> I have got one big problem with my SBC v2 . When i power up it nothnig
> happen . One time LED are turn up but when i turn switch she turn off and
> nothing happen. I try everything but i dont know know what to do. Any
> advice can be good.
> Thanks for answer.
> Martin
To unsubscribe from this group and stop receiving emails from it, send an email to n8vem+un...@googlegroups.com.
Visit this group at http://groups.google.com/group/n8vem?hl=en.
