Hi Martin! Thanks! Yes, I use an ATX power supply. If you short out some pins the power supply will work without a PC motherboard http://www.ehow.com/how_5718854_check-atx-power-supply.html There are several web pages that show this approach and You Tube videos as well. I also add a dead CD-ROM or hard drive to properly load the power supply if it is only a single PCB. Thanks and have a nice day! From: n8...@googlegroups.com [mailto:n8...@googlegroups.com] On Behalf Of Martin Bohác Hi guys ! Its again me Can i use power supply from computer for this PCB ? Thanks for answer Martin -- |
