Re: [N8VEM: 15616]
No, I don't have a smaller one than 1.8432 Mhz but I could buy one.
Op zondag 17 februari 2013 20:50:19 UTC+1 schreef vk5dg het volgende:
Have you got a slower oscillator module that you could temporarily use to clock
the Z80, preferably 1MHz or less?   The Z80 is a static device and can be clocked
down as slow as you like.  The reason I ask is that simple logic probes may
not be responsive above relatively low frequencies - I know mine is useless above
1 MHz.
David
On Monday, February 18, 2013 5:19:48 AM UTC+10:30, Sergey wrote:
>  When I measure the voltage between pin11 and 29 on the CPU I get 1.4V but
> when I measure between pin 11 and ground on the power supply pin I get 5.0V
> Any Idea where to look? What could cause the 1.4V reading on the CPU?
This is not good. If you have your ICs socketed, I'd take them out
first, and check continuity on power lines - between power connector
to ICs. Note that power pin numbers differ between ICs. For most 74*
logic, ground is the last pin in the first row (7 for 14 pin package,
8 for 16 pin, 10 for 20 pin) and Vcc is the last pin (14 for 14 pin,
etc). Same for flash/EPROM/SRAM - pin 16 is ground, pin 32 is Vcc.
Consult ICs datasheets to find power pins for other ICs. (I think
schematic omits power inputs in most cases)
Sergey
