Re: [N8VEM: 15626]
On Mon, Feb 18, 2013 at 1:00 PM, Sergey <skis...@gmail.com> wrote:
>> The reason I ask is that simple logic probes may
>> not be responsive above relatively low frequencies - I know mine is useless
>> above
>> 1 MHz.
>> David
> I found a simple logic probe useless :-) I personally use a relatively
> cheap RadioShack ($40?!) multimeter, which has a frequency meter
> (limited to 4 MHz). The frequency meter is useful for debugging
> pulsing signals. It not only shows that signal is pulsing but also
> shows the frequency.
Sergey,
Do you have a suggestion for a good logic probe? Or, are you
suggesting that a logic analyzer is required?
Thanks!
- Alex
