Re: Switch debouncing and related stuff (like CPU reset circuits)
I did try using a 555 timer as single shot multivibrator for
debouncing, but it has one problem - the 74x74 itself needs to be
reset to a known state (so that by default, after connecting the
power, ATX power supply will be off), otherwise it ends up being on or
off randomly each time power is applied (well, maybe not randomly, but
theoretically it could end up in any state). Since 74x74 doesn't have
Schmitt triggers on /SET and /RESET inputs, it is not correct to
connect an RC delay reset circuit directly to these inputs (while most
likely it will work, sometimes it might not), so I needed to use an
no it'll not work :-(
I used this in my design recently and wondered why it does not work !!
external Schmitt trigger for that anyway. So I ended up using a 74x14
for that, and for power switch debouncing.
