Re: [N8VEM: 14588] Switch debouncing and related stuff (like CPU reset circuits)
Sergey,
I've found most processor resets have enough built in capacitance that a simple schmitt provides enough hysteresis to sufficiently debounce a switch input if it's even needed at all.  But I've found many situations where the reset needs to be held for a set sequence time while the power supply is stabilizing from power-on in-rush and the simplest solution I've found - both in $$ and BoM count is a Microchip MCP130.  They tend to work well and are available in a variety of threshold voltages and in both SMT (SOT23) and through-hole (TO92) packages.  And I eliminate the need for the explicit debounce if I tie the switch to the enable on the LDO or switcher and put the MCP130 on the output side.
I've also used ATX PicoPSUs in designs and added a Maxim MAX16054 specifically to turn a simple SPST push-button into a ATX power-on toggle.  However they and some of the other parts like it from Maxim are not available in a through-hole package - only SOT23-6.
Hope this helps.
-Alan
