Re: DIY ISA backplane
Hi Wayne,
I think your idea of having the "post card" build into the back plane would be a good idea. I think the FDC would be better as a card to allow more flexibility.
Cheers,
Wayne.
On Wednesday, September 26, 2012 12:54:49 PM UTC+10, Wayne Warthen wrote:
Hi Sergey,
I would certainly be interested in the backplane as well.  Including serial ports and FDC seems useful, but I don't think it is critical since those are easy to add with adapters.  The only other idea that occurred to me was possibly including a pair of POST diagnostic HEX digit leds.  It is certainly not a big deal to me, just an idea.
The only critical thing to me is that it be ATX case mountable.
Wayne
On Tuesday, September 25, 2012 12:43:38 PM UTC-7, Sergey wrote:
Hi,
Several people asked me about getting an ISA back plane. While it is
possible to buy one, some folks would like to build one themselves.
So I am wondering how many people would like to build one?
Also I would like to collect various ideas for making the backplane.
Here is what I have in mind so far:
- Minimally sized Micro ATX board  (9.6" x 6.7" or so). It is possible
to make the board even smaller, only using the PCB space needed for
connectors and other components, but yet keep the ATX - compatible
mounting holes.
- 5 or 6 ISA slots. Note that Micro ATX only allows 4 slots, so if
using a case only 4 slots will be exposed on the back side. But still
it should be possible to use the remaining slots for cards that don't
have connectors on the back side, for example the XT-IDE card.
- ATX power connector and power on circuit (so it will work with a
momentary switch normally found in ATX cases)
- Minus 5V regulator (convert -12V to -5V). Most modern ATX power
supplies don't provide -5V (it is optional), but yet some ISA cards
use it. This circuit could be optional with a jumper to select -5V
source (ATX power supply or the backplane regulator)
- Onboard FDC and UART... maybe a couple of UARTs. I am not sure about
this one... an alternative would be making an FDC/UART ISA card, which
is more universal approach. I this case it is possible to provide two
DE9F serial port connectors with 5x2 headers connected to them (for
example to plug the XT-IDE V2 serial interface).
Any suggestions?
Sergey
