Where abouts do I find the short loop images. I've had a browse on the files section and could not find them.
Wayne.
Wayne,Here are a few steps I follow. (Some of which you have already done...)1. Verify power on all +5 pins2. make sure CPU oscillator is wiggling3. Make sure clock input to CPU is wiggling4. Make sure A0 on the flash is wiggling, maybe CE and OE as well5. Make sure clock input to UART is wiggling6. See if Tx pin on UART is wiggling after reset, if so serial wiring is likely the problem7. Use low level test images with short loops (also known as scope loops)8. When doing low level probing , if a signal is not doing what you expect you may have a problemwhere the socket pin does go into the hole, but for some reason solder hasn't reached it, reflow it and check again(test for continuity between chip lean and trace underneath the board. I have found some of these).It is possible to have a bad chip. The bottom line if following the basic functions...CPU clock is running, EEPROM is reading (if not maybe problem with I/O decoder) Check enabled on I/O devicesThese are my major thoughts. Be brave, we have all been through this difficult moment and most have working boards now.You learn a lot in this phase if you engage it enthusiastically.Regards,Douglas
