Re: SBC V2 build not working
Hi All,
Thanks for the help so far. Based on David's suggestions, i've put U10 & U14 back in, re-flashed the 29F040 with N8VEM_SW.003 and had a prod around with the scope.
Just to get everyone on the same page, this is how the board is configured now, ignoring any previous posts:
Tests:
CPU:
  1. I have both CPU Clock
  2. /RESET is high, confirmed it goes low for as long as the reset switch is held down
  3. /M1 pulsing @ 2MHz
  4. /MREQ pulsing @ 4Mhz
  5. /IORQ, /WR, /HALT, /WAIT, /INT, /NMI, /BUSAK, /BUSRQ are all high
  6. /RD is pulsing @ 2MHz
  7. /RFSH is pulsing around 2MHz
Flash
  1. /CS_ROM is pulsing. the freq changes, but it is now a proper signal I believe Scope Capture
  2. The Data lines seem to be pulsing fine Scope Capture of A0
UART
  1. I have UART clock
  2. I can see some of the Data lines D0-7 pulsing, some are low
  3. /CS_UART seems to be high all the time from power on. I wouldn't have expected the UART to be selected the whole time.
For those still with me down this far, thanks. Any pointers as to where to from here?
Wayne.
