RE: [N8VEM: 8632] Eurocard 95P
- To: <n8...@googlegroups.com>
- Subject: RE: [N8VEM: 8632] Eurocard 95P
- Date: Sat, 12 Feb 2011 13:38:46 -0500
- Authentication-results: gmr-mx.google.com; spf=pass (google.com: best guess record for domain of lyn...@yahoo.com designates 98.139.91.78 as permitted sender) smtp.mail=lyn...@yahoo.com; dkim=pass (test mode) head...@yahoo.com
- Dkim-signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=yahoo.com; s=s1024; t=1297535929; bh=nI2hvg+TP0TfME0PmC6MjkzV3R02sjk+gOQzullvcZU=; h=Received:X-Yahoo-SMTP:X-YMail-OSG:X-Yahoo-Newman-Property:From:To:References:Subject:Date:Message-ID:MIME-Version:Content-Type:Content-Transfer-Encoding:X-Mailer:Thread-Index:In-Reply-To:X-MimeOLE; b=U8kI44kkvQFimv92vmxbg4KQlZ2VSnqiXHc07Tc6PZa2fFuG+gWfqxYQ59cYXjyuFTJK3svAEaKF2xxwpEXy8qRNmBqkI1fXXTvaRVnwmewJlVauZrtr4IxCxUPLvrUWR2Mz/fNe6lSibXEevPy9RsS7U0llzDKHaLwsd5X8Qek=
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=DKIM-Signature:Received:X-Yahoo-SMTP:X-YMail-OSG:X-Yahoo-Newman-Property:From:To:References:Subject:Date:Message-ID:MIME-Version:Content-Type:Content-Transfer-Encoding:X-Mailer:Thread-Index:In-Reply-To:X-MimeOLE; b=IHC4DY4BipC4DmNfHMJ2dnsdbqTOEqIENV2iokTBCT8sLuvQuFvSoVoaIxOZMg6PitkTwqAJD1a1HFonSO634vt4DbnZc0TYJnF7HiC8fgS1a8BHKoMkx/XgL6qZJF4ifn52JtdZc5MayXXNQPjZzA1778pOcvaaWoVuvOktOQ0= ;
- In-reply-to: <4D55B7F6.6040906@gmail.com>
- References: <dbef6cd7-eb0d-417d-9d9c-c662f9ef0e89@z9g2000yqz.googlegroups.com> <74C32330D920405EAFF97C1D95CFDC26@andrewdesktop> <AANLkTikiGagWddeX4zsPfiW7bzsVVTV8USkzozPm0vOr@mail.gmail.com> <84380222F68F498284FE9F47C1FE0EB3@andrewdesktop> <D040CD20563141748C11B4FB055B557F@andrewdesktop> <D96921AEC6574115A933D4645BB78A4D@andrewdesktop> <AANLkTimLu1MfT2T9MogBVBkrONWvGm+83kPAuiK9eaW3@mail.gmail.com> <9CF7BA54634B48D8806306F28BA3B19B@andrewdesktop> <AANLkTikm9XBbq1EA=k013Eap+z6VHwOXZNYmekYnN04a@mail.gmail.com> <9ff0975d-87b2-4668-95a5-c0f16d8849cb@k22g2000yqh.googlegroups.com> <AANLkTi=-EBZ7WWbRY8+2bzoC7F4Nokdp5yW+k6PCa_yD@mail.gmail.com> <03a1b786-fb86-49ca-8910-a5b01042456d@f20g2000prn.googlegroups.com> <AANLkTikK89iTh6e_um75D56Lo9JpfT4WxZfOAVcKhyDJ@mail.gmail.com> <4b181ab9-5b19-4dd2-8c98-e4f04d3be16f@g1g2000prb.googlegroups.com> <AANLkTim7VuLat_PHQXopYTimOWM-_1t3=2VaJydNb4n9@mail.gmail.com> <AANLkTi=vYXNS81Z3cs1UNi6-ieXHsLDEe_KMPmE__P8b@mail.gmail.com> <4D55B7F6.6040906@gmail.com>
- Thread-index: AcvKOp4fOjujt6inQe2hb6N+SQr3SAAoincg
Hi Don! Thanks! I have not used the press pin version. I suspect it
requires a specific type of plated through hole for it to work and would
probably damage regular PTHs on the PCB. However, I've not tried it so it
may work but you'll need to press it in and that will require some force. I
recommend using the regular solder tab style DIN 41612 connector. If you
get the press pin version to work please post how you did it on the mailing
list so other builders can see it. It would be nice to know if they can
work since I think other builders have gotten them by accident as well.
Thanks and have a nice day!
Andrew Lynch
> -----Original Message-----
> Don Caprio
> Sent: Friday, February 11, 2011 5:28 PM
> To: n8...@googlegroups.com
> Subject: [N8VEM: 8632] Eurocard 95P
> I ordered the N8VEM Eurocard connector from Mouser and got the press pin
> version by mistake.
> Mouser was nice enough to send me replacements at no cost :^)
> Have any of you used the press pin version?
> Sounds like a special tool is needed to press them in. Could I use
> some wood blocks and a vice? The connectors on the ends look like
> they would be difficult to press in but the center ones look doable.
> My concern is damaging the PCB board.
> thanks.
> Don Caprio
> ilv...@gmail.com
> You received this message because you are subscribed to the Google Groups
> "N8VEM" group.
> To unsubscribe from this group, send email to
> n8vem+un...@googlegroups.com.
> For more options, visit this group at
> http://groups.google.com/group/n8vem?hl=en.
