RE: [N8VEM: 2481] Re: Disk I/O IDE Session Log
- To: <n8...@googlegroups.com>
- Subject: RE: [N8VEM: 2481] Re: Disk I/O IDE Session Log
- Date: Tue, 10 Feb 2009 20:27:12 -0500
- Authentication-results: mx.google.com; spf=pass (google.com: domain of lyn...@yahoo.com designates 68.142.229.104 as permitted sender) smtp.mail=lyn...@yahoo.com; domainkeys=pass (test mode) header.From=lyn...@yahoo.com
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Received:X-YMail-OSG:X-Yahoo-Newman-Property:From:To:References:Subject:Date:Message-ID:MIME-Version:Content-Type:Content-Transfer-Encoding:X-Mailer:thread-index:X-MimeOLE:In-Reply-To; b=i/VJenK7N8T46iFFfLP5R4mO9phFCflE1JJw6aDjoG+tbK488V/ZuAYVnqOX6ezxrG23N/JhZFWPVvwewl0LrpQCDA8f472NHYzxXowno1J012yyyNCCC3vnwDQmlfuDns2hjISFjTAt5aP/ImXEvMRuQ0lg/Kgg9RciPWES6m8= ;
- Domainkey-status: good (test mode)
- In-reply-to: <C5B78245.27C00%rcini@optonline.net>
- References: <59942377DF2D450AADAD8332F240130A@andrewdesktop> <C5B78245.27C00%rcini@optonline.net>
- Thread-index: AcmKYiptZ39wxxiLTaOs4m47r+7T9QAAa9ZAAF5qxn8AAf3MkA==
Hi Rich! This is getting better by the moment! I just noticed that pin 27
on the XT-IDE project (IORDY) has a 10K ohm pull down resistor on it. It is
a wonder anyone gets an IDE interface to work at all!
It appears the IORDY is an output from the IDE hard drive so I cannot see
why that would be pulled low on the controller side.
Thanks and have a nice day!
Andrew Lynch
> -----Original Message-----
> Richard A. Cini
> Sent: Tuesday, February 10, 2009 7:13 PM
> To: N8VEM-Post
> Subject: [N8VEM: 2481] Re: Disk I/O IDE Session Log
> All:
> Andrew sent me a few links to Web sites used as ³inspiration² for the
> Disk-I/O interface. The information is inconsistent (again, the IDE/ATA
> "standard" is so flexible), but basically here¹s what I¹ve concluded
> today:
> If the host controller isn¹t using DMA, DMARQ (an output signal from
> the
> drive) should be left floating (this is R2).
[AJL>]
Agree. Pulling low an IDE hard drive output makes no sense in retrospect
even though some IDE interface designs incorporate it anyway.
> /DMACK is an output from the host to the drive. If DMA isn¹t being
> used,
> it should be pulled-up. The current Disk-I/O schematic shows it as being
> pulled down.
[AJL>]
Agree. Easy fix to cut the GND trace leading to R3 and add a jumper to VCC.
> For Cable Select (CSEL), it appears that the drive usually provides
> the
> 10k pull-up. If not using Cable Select, make sure to use the jumper on the
> drive to select Master so that it's pulled-down.
[AJL>]
Agree.
> So, for testing purposes (tonight hopefully), I plan on pulling the
> bottom legs (closest to the IDE connector) of R1 (CSEL pull-up) and R2
> (DMARQ pull-up), and R3 and connecting the free leg of R3 to Vcc (to
> create
> a pull-up rather than a pull-down). People¹s experience with their drives
> working with all resistors removed is consistent with what I outlined
> above
> with the exception of the pull-up on /DMACK.
[AJL>]
Good luck my friend! Good hunting!
Andrew Lynch
PS, I fear we will be going through this all over again with the 8 bit IDE
project on the VCF so save your notes! There are all sorts of squirrelly
stuff on the XT-IDE design as well. I am glad to have insisted on building
a prototype for them or it probably would have ended badly! That's no
guarantee but it's better than the guess game that the IDE "standard" is
turning out to be! :-)
> Rich
> Rich Cini
> Collector of Classic Computers
> Build Master and lead engineer, Altair32 Emulator
> http://www.altair32.com
> http://www.classiccmp.org/cini
