Minor bug - won't display 9 to 15 correctly. Rich, can you just double
check the code below and maybe post the original 8080 code...
USRPAT:
UPAT1: CALL GETUSR ;call ccp routine to
; get current user number.
CP 09 ;check if zero thru nine
; or if two digits
; ten thru fifteen.
JP NC,UPDBL ;jump if two digits.
ADD A,30h ;else convert to ascii.
UPSING: CALL PRINT ;call ccp conout routine.
RET ;return where ccp left off.
UPDBL: ADD A,26h ;subtract 10 from the user
; number; the remainder
; will be the second digit.
; Add 30 to convert it to
; ascii or just add 26h to
; accomplish both.
PUSH AF ;save the second digit
ADD A,31h ;load an ascii 'one'
POP AF ;return second digit
JP UPSING ;output second digit
; and return
RET
