Re: New Peripheral board - Request for Comment
Ah, so if you are going vga/sd/keyboard on the prop that limits the
pins you can use on the prop. I was thinking if you had all the pins
on the prop free you could do all sorts of things eg laplink which I
think used 15 pins for bidirectional parallel comms at up to
3megabits. Speed vs pins. Can you set a cog going dedicated just to
comms so then vga etc doesn't slow things down as much?
