Home » RBC Forums » General Discussion » N8 (4314) RomWBW 3.0.1 and PPIDE
N8 (4314) RomWBW 3.0.1 and PPIDE [message #8264] Sun, 31 January 2021 02:45 Go to previous message
andrii_kutepov is currently offline  andrii_kutepov
Hi,
Can't make PPIDE work on N8 (4314).
I add to my config file
PPIDEENABLE .SET TRUE ; PPIDE: ENABLE PARALLEL PORT IDE DISK DRIVER (PPIDE.ASM)
PPIDE0A8BIT .SET TRUE ; PPIDE 0A (MASTER): 8 BIT XFER
PPIDE0B8BIT .SET TRUE ; PPIDE 0B (SLAVE): 8 BIT XFER
PPIDE0BASE .SET $80 ; PPIDE 1: PPI REGISTERS BASE ADR
I'm use some previous tested CF's with CF-IDE adapter, different tested ppi 8255. Double check all signal and pcb track.
also added wait states on IO and memory.
Without a result. The card is not determined at the start. Sometimes with different errors.
The question arose when I didn't find a file .\Doc\Testing Notes.txt
mention of the testing of the ppide. there's only this:
N8-2312 (X)
- Test ASCI driver
- Test SD driver (CSIO mode)
- Test FD driver
- Test FDU app
- Test TMS driver (video & kbd)
Please say should PPIDE work on N8 with this BIOS ?
Thanks
Andrii
[Updated on: Sun, 31 January 2021 02:45]
Read Message
Read Message
Read Message
Read Message
Previous Topic: Ended up with some extra 74F133N ICs for the KISS-68030
Next Topic: RC2014 Z80 /WR and /RD mutually exclusive?
Current Time: Sat Apr 26 13:30:43 PDT 2025
Total time taken to generate the page: 0.00647 seconds
