Home » RBC Forums » General Discussion » Z80 computer - wirewrap hybrid
Z80 computer - wirewrap hybrid [message #4979] Sat, 04 August 2018 02:47 Go to previous message
linker3000 is currently offline  linker3000
Hi everyone, I've just finished my Z80 build - it's based on Grant Searle's design but with most of the glue logic replaced with a GAL. I've used perfboard and standard IC sockets with header pins instead of wirewrap sockets, so it's a bit of a hybrid.
https://i.imgur.com/7y7Notl.jpg
More pics here: https://imgur.com/a/rGRR2NM
This is going to be a chip testing and a show-and-tell board used for STEM classes, so the build reduces handling and risk of snags/wire pulls if it can stay put and everyone can see the components and wirewrapping at the same time. Additionally, wirewrap IC sockets are becoming expensive in small quantities + I have a large stock of regular IC sockets and header pins!!
The only component purchased specifically for this build was the EPROM - and that was only because I has having problems programming a couple from my old stock (then I found out my programmer was faulty).
Chips: Z80 CPU (Mostek MK3880N-4 second-source, date stamped 1980) + 27C128 EPROM + 628128 SRAM + Z80 SIO/0 UART + 74HCT00 + GAL20V8B
Schematic and GAL programming details here: https://github.com/linker3000/Z80-Board
This board just runs MS Z80 ROM BASIC right now; the next step is to add the compact flash/IDE card for CP/M and program storage and that will be it for this board.
Board #2 will have a Eurocard (ECB) interface and banked ROM for expansion + be built on a PCB.
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic: Surpluss SBC
Next Topic: Z80 DMA
Current Time: Fri Sep 26 15:45:38 PDT 2025
Total time taken to generate the page: 0.30000 seconds
