Home » RBC Forums » General Discussion » Resurrecting EaZy80, a forgotten glue-less 22MHz Z80 SBC. (Z80, KIO, Glueless SBC)
Resurrecting EaZy80, a forgotten glue-less 22MHz Z80 SBC. [message #10511] Sun, 19 November 2023 18:14 Go to next message
EaZy80 was a 4-1/2 year pc board design that was forgotten. It was not assembled and powered up until recently when I rediscovered it while rummaging through pc boards. The design approach was a glue-less Z80 SBC very similar to Simple80 but used KIO (Z84C90) for I/O. KIO is much faster than Simple80's SIO thus can run at much higher CPU clock. The nominal operating frequency of EaZy80 is 22MHz, but it has been overclocked to 31MHz successfully. Second picture shows it working with Simple80's CF board to run CP/M.
I generally design with CPLD, but this is one of few designs without CPLD, so it is easy to find parts and put one together. While the parallel CF interface is faster, KIO has plenty of IO lines to bit-bang SD disk and talk to DS1302 RTC, so a CP/M computer can be created without any glue logic.
EaZy80 has 128K of RAM. The 2nd bank of 64K is accessible by manipulating KIO's PC0 output. Bank sharing routines are installed at high end of both RAM banks, so data can be shared between two banks. Ladislau Szilagyi has enhanced HiTec C and TE editor for Simple80 based on these bank sharing routines. I believe the same routines will also work for EaZy80.
Another thing to explore is replacing the 128K RAM with 512K RAM and port RomWBW to it. However, I don't know how to do that with 8 banks of 64K RAM, but with the addition of a quad OR gate (7432), 16 32K banks are possible which definitely will support RomWBW.
I created a homepage for EaZy80 here:
https://www.retrobrewcomputers.org/doku.php?id=builderpages: plasmo:eazy80:rev0pcb:eazy80r0home
/forum/index.php?t=getfile&id=2948&private=0
/forum/index.php?t=getfile&id=2947&private=0
Re: Resurrecting EaZy80, a forgotten glue-less 22MHz Z80 SBC. [message #10852 is a reply to message #10511] Sat, 23 November 2024 18:05 Go to previous messageGo to next message
Eazy80 rev0 has been updated to rev1 which corrected all bodges in rev0 pc board. It is functionally same as rev0, but the three RC2014 expansion connectors are replaced with prototype area to facilitate experimentation with KIO. Homepage for rev1 of Eazy80 is:
https://www.retrobrewcomputers.org/doku.php?id=builderpages: plasmo:eazy80:eazy80r1pcb:eazy80r1home
One feature added to Eazy80 rev1 is an uncommitted 14-pin DIP for experimenting with 512K RAM and RomWBW. I have demonstrated that RomWBW can be ported to Eazy80 by replacing 128K RAM with 512K RAM, adding a SD card, and wiring in a 74HCT32 in the 14-pin DIP location. The RomWBW conversion is documented in this section of the homepage:
https://www.retrobrewcomputers.org/doku.php?id=builderpages: plasmo:eazy80:eazy80r1pcb:eazy80r1home#eazy80_modifications_ for_romwbw
/forum/index.php?t=getfile&id=3105&private=0
Re: Resurrecting EaZy80, a forgotten glue-less 22MHz Z80 SBC. [message #10853 is a reply to message #10852] Sun, 24 November 2024 08:23 Go to previous messageGo to next message
Excellent job, Plasmo!!! How difficult is it to find a KIO these days?
Re: Resurrecting EaZy80, a forgotten glue-less 22MHz Z80 SBC. [message #10854 is a reply to message #10853] Sun, 24 November 2024 20:37 Go to previous messageGo to next message
Eazy80 was designed with this kit in mind: https://www.ebay.com/itm/116032696403
I've purchased several kits in the past and checked out the components. The kit is still being offered right now.
I've also purchased KIO from utsource.net.
Re: Resurrecting EaZy80, a forgotten glue-less 22MHz Z80 SBC. [message #10856 is a reply to message #10854] Sat, 30 November 2024 08:18 Go to previous messageGo to next message
I've been thinking about maybe trying to build one of these. Plasmo has been helping me try to translate the PCB layout to KiCAD. If anyone is thinking about doing that, be warned that the PLCC-84 footprint in KiCAD is screwed up. The default one that I picked up has duplicate numbering of some pins, and some pin numbers completely missing. I'm no KiCAD expert, but I *think* that my version (4.0) of KiCAD gets its footprints from the GitHub repository on-line? I *think* I found a good module library with a good PLCC-84 in the /usr/share/kicad directory as installed on my system. Getting KiCAD to ignore the broken footprint and pick up the good one was quite an adventure!! As I said, I'm not very well versed in the ins and outs of KiCAD.
Bottom line: take a careful look at the pin numbering of the KiCAD PLCC-84 footprint if you try to use it!
Re: Resurrecting EaZy80, a forgotten glue-less 22MHz Z80 SBC. [message #10857 is a reply to message #10856] Sun, 01 December 2024 05:45 Go to previous message
KiCad 4.0? Ouch. Is there a reason why you don't download and use KiCad 8.0?
Previous Topic: General Instrument CTS256A-AL2 vs. Microchip CTS256AL2
Next Topic: Recompiling bios for the sbc-188
Current Time: Tue Mar 25 22:25:41 PDT 2025
Total time taken to generate the page: 0.02313 seconds
