Home » RBC Forums » General Discussion » Any i860 fans here? (i860 cray)
Any i860 fans here? [message #10135] Sun, 18 September 2022 05:42 Go to next message
e2k is currently offline  e2k
Anybody still plays with intel's idea of a "cray for the poor"?
Chips are easy to get, and was a funny chip ...
Re: Any i860 fans here? [message #10137 is a reply to message #10135] Mon, 19 September 2022 19:14 Go to previous messageGo to next message
cheshirenoir is currently offline  cheshirenoir
I mostly remember the i860 being used in a LOT of Postscript printers in the early 90s.
Chesh
Re: Any i860 fans here? [message #10138 is a reply to message #10137] Tue, 20 September 2022 05:05 Go to previous messageGo to next message
I have some graphic cards with i860s, and it was also used on massive parallel compuiting:
https://en.wikipedia.org/wiki/Intel_Paragon
I would just like to make my own board with one ("1") ;-)
[Updated on: Tue, 20 September 2022 05:05]
Re: Any i860 fans here? [message #10146 is a reply to message #10138] Wed, 12 October 2022 12:28 Go to previous messageGo to next message
Would love a usable CPU board with one but no idea what it would actually be useful for Cool
Re: Any i860 fans here? [message #10150 is a reply to message #10146] Tue, 18 October 2022 23:25 Go to previous messageGo to next message
etchedpixels wrote on Wed, 12 October 2022 12:28
If I would ask this question for every item, I have in storage Smile
icon14.gif  Re: Any i860 fans here? [message #10205 is a reply to message #10150] Fri, 20 January 2023 08:19 Go to previous messageGo to next message
trianon is currently offline  trianon
I had no idea that these CPU are easy to find, where can I buy them ?
A very long time ago I designed an i960 processor board, we first had a look at
the i860 but this was a little overkill at the time.
Now and then I still have a look in old data books about the full risc family.
Would be nice to get an development board with an i860 and write some code Razz
Re: Any i860 fans here? [message #10206 is a reply to message #10205] Sat, 21 January 2023 04:49 Go to previous messageGo to next message
I'm stuck at the moment, in getting any compiler for it to work. If I could be sure, I have SW for it,
I would make some boards ...
Re: Any i860 fans here? [message #10214 is a reply to message #10206] Sat, 28 January 2023 13:48 Go to previous messageGo to next message
gcc used to work. You may need to build a couple of progressively older gcc compilers to build a gcc that can build an old enough gcc for i860.
What specific problems do you have and I'll take a look at cooking something up.
Alan
Re: Any i860 fans here? [message #10216 is a reply to message #10214] Sun, 29 January 2023 03:25 Go to previous messageGo to next message
etchedpixels wrote on Sat, 28 January 2023 13:48
Alan
I really tried a lot of combinations, (on ubuntu 22LTS) but sure, I could have missed something ...
IIRC, around gcc 4.* the i860 code was slowly removed. (pretty much with the announcement of 4.0, but it was still there)
Not the same combinations of switches worked for both (binutils & gcc). sometime SYSV gave you binutils, sometimes it didn't
(sorry, sitting in the wrong office, can't check what I did)
So the "sweet spot" to have a chance, would be around late 3.* or very early 4.0, but again, couldn't find the right compiler switches ...
Re: Any i860 fans here? [message #10217 is a reply to message #10216] Sun, 29 January 2023 06:22 Go to previous messageGo to next message
Having a dig back in history
../binutils-2.26.1/configure --target=i860-stardent-elf --prefix=/opt/i860 --disable-multilib
gets you a binutils
../gcc-3.4.6/configure --target=i860-sysv4 --prefix=/opt/i860 --disable-multilib --disable-threads --enable-languages=c --disable-shared --without-headers --disable-libssp --disable-libmpx --disable-libatomic
gets you compiler
But the two don't agree. I'll have a further poke later to figure out the rest of the incantations
Re: Any i860 fans here? [message #10218 is a reply to message #10217] Sun, 29 January 2023 08:15 Go to previous messageGo to next message
Ok the following incantations appear to work
../binutils-2.14/configure --target=i860-stardent-sysv4 --prefix=/opt/i860 --disable-multilib
make
make install
(there are probably later ones that still have the right support. I didn't look too hard)
Ensure the resulting i860 directory is on your path
edit gcc/config/i860/i860.md
go to line 1229
Comment out the stanza
;; AC
;;(define_insn ""
;; [(set (match_operand:QI 0 "register_operand" "=r")
;; (match_operand:QI 1 "indexed_operand" "m")Wink]
;; "ld.b %1,%0")
which appears to be a bug that never got fixed upstream
../gcc-3.4.6/configure --target=i860-stardent-sysv4 --prefix=/opt/i860 --disable-multilib --disable-threads --enable-languages=c --disable-shared --without-headers --disable-libssp --disable-libmpx --disable-libatomic
make
make install
[Updated on: Sun, 29 January 2023 08:16]
Re: Any i860 fans here? [message #10219 is a reply to message #10218] Mon, 30 January 2023 04:26 Go to previous messageGo to next message
etchedpixels wrote on Sun, 29 January 2023 08:15
Hello again, THANKS for that, you definitely got me on the right track.
On my system (Ubuntu 22LTS, gcc 11) it didn't work completely, but the flags/switches seems to be right.
Tried binutils 2.14, 2.15, 2.16.1, 2.17, 2.18, 2.19.1, 2.20.1 ... Finally, 2.25.1 worked
gcc-3.4.6 worked, after some massaging Smile
gcc-4.0.* all failed with internal compiler error
after that, support for the i860 was removed.
THANKS again!
Re: Any i860 fans here? [message #10258 is a reply to message #10135] Fri, 03 March 2023 04:08 Go to previous message
drogon is currently offline  drogon
e2k wrote on Sun, 18 September 2022 13:42
A bit late to the party, but I've only just remembered about this place ...
I did some work with the i860 back in its day - I worked for a UK Supercomputer computer company and they were a stop-gap from Transputer to Sparc... 40Mhz, capable of 3 instructions per cycle (in-theory) so they seemed like a good thing - and they were - but were a right PITA to code for.
They are a 32-bit RISC CPU with MMU and the Integer side was fairly nice/orthogonal but the floating point side... The chip has a 64-bit data bus and can read 2 instructions at a time. One is for the Integer CPU, the other for the floating point unit. This was called dual-instruction mode - and since one FP operation is a combined multiply and add, this is where it gets the 3 instructions per cycle claim from.
The FP side has to be "hand cranked". So you'd typically use the integer instructions to load a value into the FP pipeline, then 8 cycles later (IIRC) the result would come out, meanwhile you have to use those 7 cycles to continue to load another 7 FP values in the pipeline - so there was a latency for individual operations, but matrix operations would fly and could crank out FFTs and things where multiply and add was a good thing but the code had to be very carefully done by hand - later tools did help though (but that was after my time with them). I've no idea if the last supported GCC could 'vectorise' operations or not.
The biggest headache was taking an interrupt. Then you had to flush and save the state of the FP pipeline, restore the FP pipeline for the interrupt process and carry on. This took several 100 cycles (again, IIRC). So as an embedded system with no interrupts (or simple interrupts that didn't need to touch the FP side) it might be fine, but to use it for e.g. Unix (and I think there was a Unix for it at one point), was somewhat sub-optimal.
Anyway there you go. I load a good few braincells to dual-instruction mode but it was fun at the time. I understand a lot of the internals of it made it into the MMX, etc. instructions in later Pentiums.
-Gordon
Previous Topic: DOS/65 by Richard Leary
Next Topic: Omega MSX clone parts for sale
Current Time: Mon Apr 28 12:16:28 PDT 2025
Total time taken to generate the page: 0.00772 seconds
