Home » RBC Forums » General Discussion » xmodem-1K, ymodem, or zmodem (improved data transfer programs for CP/M)
xmodem-1K, ymodem, or zmodem [message #8911] Wed, 28 July 2021 07:23 Go to next message
One of the first programs often ported to a new RBC system is xmodem usually right after the debugger and CP/M-2.2. I have been using xmodem 5.0 for many years and while it works great at what it does the decision to use 128 byte packets rather hobbles it due to a lot of overhead. Also it does not support automatic file names or start up or many other advanced features. Kermit is an improvement but still pretty slow compared to the more advanced file transfer protocol programs.
I recall using xmodem-1K, ymodem, and zmodem on the IBM PC clones many years ago and they are much faster and more capable than the original xmodem. Are any of these available for CP/M-80 2.2? I've seen there is a terminal program for CP/M which supports zmodem (ZMP) but I think I am looking for something the other way around. Normally I use minicom on a Linux notebook as a terminal to the Z80 MBC and xmodem as the file transfer tool.
Has anyone used ZMP? https://github.com/mecparts/zmp can it be used as just a file transfer program?
Like to hear people's thoughts and wisdom on this subject. I am hoping there is some great but unnoticed file transfer program available
Re: xmodem-1K, ymodem, or zmodem [message #8912 is a reply to message #8911] Wed, 28 July 2021 08:11 Go to previous messageGo to next message
edzard is currently offline  edzard
Hello Andrew,
There is a program called FIFOPIPE. It's developed by William Sowerbutts.
I never used it (but want too, when I get my Z80 up-and-running).
Don't know if it works standalone of in conjunction with his USB FIFO board.
https:// www.retrobrewcomputers.org/doku.php?id=boards:ecb:usb-fifo:s tart
Best regards,
Edzard
Re: xmodem-1K, ymodem, or zmodem [message #8913 is a reply to message #8912] Wed, 28 July 2021 11:56 Go to previous messageGo to next message
scruss is currently offline  scruss
In a great piece of software asymmetry, I've found that XMODEM5 supports sending files using xmodem-1k, but rx on linux doesn't support xmodem-1k.
zmodem's file name support was magic. Use a terminal that auto-detected incoming downloads, you didn't have to worry about missing a download
> Does anyone know what each of the pins on the 6502 CPU chip in the Apple II Plus does?
They all plug into the socket on the motherboard to keep the chip from drifting away. - c.s.a2 FAQ of yore
Re: xmodem-1K, ymodem, or zmodem [message #8915 is a reply to message #8913] Thu, 29 July 2021 03:15 Go to previous messageGo to next message
scruss wrote on Wed, 28 July 2021 14:56
Well that explains why xmodem-1K never works on my Linux notebook computer. Always wondered why and now I know. Thanks!
Has anyone tried ZMP for CP/M? What did were the results? It looks like it will need to be configured and compiled using a specific C compiler but that's just a quick observation and may not be the case
Re: xmodem-1K, ymodem, or zmodem [message #8927 is a reply to message #8915] Sat, 31 July 2021 11:06 Go to previous messageGo to next message
Hi Andrew,
I got stuck on this previously too but ended up using kermit for transferring bulk files with filenames. I found it pretty aweful but it must have been a tool that solved a problem in it's era.
A tonne of work has been done on hitech-c https://github.com/agn453/HI-TECH-Z80-C so maybe a rebuild would not be that difficult.
Best Wishes Phil.
Best wishes Phil.
Re: xmodem-1K, ymodem, or zmodem [message #8992 is a reply to message #8927] Wed, 11 August 2021 07:41 Go to previous messageGo to next message
I had a shot at getting zmp15 ( http://cpmarchives.classiccmp.org/cpm/mirrors/oak.oakland.ed u/pub/cpm/zmodem/) working under ROMWBW.
I've created a ROMWBW overlay and get some screen output and serial modem initialization on the output but get not further input or output.
Was wondering if anyone else had any experience or had a working version on any platform?
Thanks.
/forum/index.php?t=getfile&id=2332&private=0
  • Attachment: zmp.png
    (Size: 25.33KB, Downloaded 1507 times)
  • Attachment: zmp-blnk.z80
    (Size: 12.57KB, Downloaded 278 times)
[Updated on: Wed, 11 August 2021 08:20] by Moderator
Re: xmodem-1K, ymodem, or zmodem [message #8993 is a reply to message #8992] Wed, 11 August 2021 08:20 Go to previous messageGo to next message
Hi Phil
Awesome! I think ZMP will be a great addition to RomWBW
Re: xmodem-1K, ymodem, or zmodem [message #9002 is a reply to message #8993] Wed, 11 August 2021 17:47 Go to previous messageGo to next message
Wayne W is currently offline  Wayne W
Hi Phil,
This is interesting.
Could it just be that XMP is waiting for the typical "OK" response from a Hayes modem?
-Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9009 is a reply to message #9002] Thu, 12 August 2021 06:46 Go to previous messageGo to next message
Hi Wayne, thanks, yes I tried that but it is not expecting an OK response.
Managed to make some progress. Amoungst other things, the main issue was that registers saves were required.
Program now functional but no successful transfer. Currently hard coded to my usbfifo cio. Happy with progress so far.
/forum/index.php?t=getfile&id=2341&private=0
  • Attachment: zmpxfer.png
    (Size: 36.77KB, Downloaded 1488 times)
Re: xmodem-1K, ymodem, or zmodem [message #9014 is a reply to message #9009] Thu, 12 August 2021 12:34 Go to previous messageGo to next message
OK, Phil. Hope you can get it working.
-Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9024 is a reply to message #9014] Thu, 19 August 2021 07:49 Go to previous messageGo to next message
Hi Guys, Need some help with this...
I've attached mecparts.lbr which is the redevelopment version of zmp and also the hbios overlay.
Zmodem send works but I can't get receive to work.
Would someone be able to try this out and confirm they get the same results? You need a second serial port to try this.
Library includes the overlay source, which is already installed in zmp.com.
You can install an updated overlay by using
z80asm zmo-rw01/h
mload zmp.com=zmpx.com,zmo-rw01
I tried this on the original zmp15 package and get the same results.
Unsure if it has something to do with my serial port which is a usb-fifo.
Thanks!
  • Attachment: mecparts.lbr
    (Size: 132.25KB, Downloaded 290 times)
Re: xmodem, ymodem, zmodem [message #9025 is a reply to message #9024] Fri, 20 August 2021 06:26 Go to previous messageGo to next message
jayindallas is currently offline  jayindallas
These three names X/Y/Zmodem invoke memories of the CP/M+Modem experiences of the 80s.
This sequence equate into the cringe of getting a remote connection to a computer I fixed up for my parents, so I could transfer a file to their system. Their system had 8" drives, mine were 5.25" drives, so it was better if I could send the files to their computer before I arrived to install it.
With X-modem and a one-phoneline household at the remote end, I had to spend 30 minutes to an hour telling them the keyboard sequence they'd have to type once they hungup the phone and activated the modem for my call... plus all the trial and error of their keystrokes and the many attempts to start-over. It was so nearly impossible that I paid to put a second phoneline in their house for the modem, so I could live-chat them through the process. I liked X-Modem in general, but these particular transfers still haunt me. Smile
Y-modem was nice improvement. The walkthrough time seems like it dropped to 15 to 5 minutes. In comparison to X-Modem it seemed like the ultimate improvement... at the time.
Z-Modem was THE REAL great improvement, I just had to tell them to turn the modem on and I could handle most everything on my end of the call.
I don't remember much about the modem commands I had to talk them through, back in the day, my memory of them are all about the time it took to get my parents to enter the necessary commands on their side of the connection.
Glad that doesn't need to happen anymore. Smile
[Updated on: Fri, 20 August 2021 06:44]
Re: xmodem-1K, ymodem, or zmodem [message #9027 is a reply to message #9024] Fri, 20 August 2021 19:47 Go to previous messageGo to next message
b1ackmai1er wrote on Thu, 19 August 2021 07:49
I will play with this tomorrow Phil.
-Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9028 is a reply to message #9027] Sat, 21 August 2021 12:36 Go to previous messageGo to next message
Hi Phil,
I was ultimately successful. Initially, I found that I could do XModem send or receive and YModem send or receive. I could, as did you, do ZModem send. When I tried ZModem receive, I got "Subpkt too long" errors (see first screenshot). After some head scratching, I found that Tera Term has a ZModem parameter called "ZmodemWinSize". It was set to 32767 in the default configuration. I changed this to 4096, and ZModem receive began to work. This setting applies to the remote side of the connection. See the second screenshot.
Oh, I should mention that the ZmodemWinSize setting in Tera Term is found in the .INI file that Tera Term uses to save settings. It is not found anywhere in the user interface itself, so you need to edit the .INI file directly.
The obvious conclusion from all this is that modern implementations of ZModem assume a larger working buffer on the other side than is reasonably available on an 8-bit system. This was an interesting challenge.
Anyway, hope this is helpful. ZMP appears to be a truly worthwhile application.
Thanks for working on this!
-Wayne
/forum/index.php?t=getfile&id=2348&private=0
/forum/index.php?t=getfile&id=2349&private=0
Re: xmodem-1K, ymodem, or zmodem [message #9029 is a reply to message #9028] Sat, 21 August 2021 18:15 Go to previous messageGo to next message
Thanks Wayne!
I had tried these settings on my machine
ZmodemDataLen=128
ZmodemWinSize=4096
which improved but did not resolve the issue.
I tried swapping the CIO order but that is giving me some weirdness, so it looks like an issue with my machine/configuration.
Did you want submit ass an app or as a build package for romwbw?
Thanks for your help.
[Updated on: Sat, 21 August 2021 18:15]
Re: xmodem-1K, ymodem, or zmodem [message #9030 is a reply to message #9029] Sat, 21 August 2021 19:04 Go to previous messageGo to next message
I, too, need help.
extract mecparts.lbr with LU310.com to drive A
I modified ZmodemWinSize=4096
My hardware is ZRC with 14.7MHz clock running a version of ROMWBW that loads ROM & RAM contents to 2meg DRAM. The serial port is emulated 68B50.
When run ZMP, I get:
Initializing port ...
Unable to initialize port A
I edited zmo-rw01.z80 and changed the clkspd to 15 and reassemble according to the instruction:
z80asm zmo-rw01/h
But I still have the same "Unable to initialize port A" message
Maybe my hardware is just too weird. Tell me what kinda hardware you are using and I'll try to match.
/forum/index.php?t=getfile&id=2350&private=0
Re: xmodem-1K, ymodem, or zmodem [message #9031 is a reply to message #9030] Sat, 21 August 2021 20:04 Go to previous messageGo to next message
plasmo wrote on Sat, 21 August 2021 19:04
I, too, need help.
Hi Bill,
I think the ZRC has just a single serial port, right? ZMP requires that the communication port be different from the console port. It looks like Phil has implemented the ZMP serial driver so that communication port A is actually the second serial port in the system. Port B would be third serial port. So, I suspect the initialization error is simply that there is no serial port there.
@Phil: It looks like ZMP has some concept for choosing the communication port, but I was unable to figure it out. Do you know how to choose ZMP port B, etc.?
Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9032 is a reply to message #9031] Sun, 22 August 2021 02:06 Go to previous messageGo to next message
Hi Bill, Wayne,
The version of zmodem I have attached is https://github.com/mecparts/zmp which is re-implementation of zmp based on the last available code release of Ron Murray's zmp.
One of the changes in this reimplemetation is that it does not support multiple ports. i.e. it only supports console and one comm. port.
The driver still supports ability to switch ports (Two comm. ports - A & B) and can be used with the original zmp but both versions do require a separate comms. port for the transfer, separate to the console.
Also, this version is coded for romwbw so speed determination is obtained from the hbios - clkspd equate is unused. On the ZRC there is only one character input-ouput device (console) which is why you are getting the error initializing port A which is defined as the second character input output device. So you need two serial ports for this to work.
Regards Phil.
Re: xmodem-1K, ymodem, or zmodem [message #9033 is a reply to message #9032] Sun, 22 August 2021 03:46 Go to previous messageGo to next message
This is the original Ron Murray zmp15 with the romwbw overlay that supports port switching.
This does not work for me either. overlay may be slightly different to original one I posted.
Regards Phil.
Edit:removed - still had debug code in it. will reupload later.
[Updated on: Sun, 22 August 2021 04:22]
Re: xmodem-1K, ymodem, or zmodem [message #9034 is a reply to message #9029] Sun, 22 August 2021 07:01 Go to previous messageGo to next message
b1ackmai1er wrote on Sat, 21 August 2021 18:15
ZmodemDataLen=128
ZmodemWinSize=4096
Hmmm... that's disappointing. I think you said you are using your USB-FIFO interface. I am going to try some other systems with different serial hardware and see if anything changes for me. I was using my Mark IV system for testing. The console was on the first ASCI port. I used John Coffman's 4 port serial board for the communication port. I hacked the proper port value into the overlay to achieve this.
I think I would prefer to have a build package. Similar to the way that XM is built. If I understand correctly, it will requite Hi-Tech C, right? That will will require some work because it probably means adding some files to the Tools/zx/cpm/... directories.
Before submitting a pull request, could you describe what is needed?
Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9035 is a reply to message #9032] Sun, 22 August 2021 07:08 Go to previous messageGo to next message
b1ackmai1er wrote on Sun, 22 August 2021 02:06
Ah, OK, that explains it. I saw the setport routine in the overlay, but no way to use it and it did not seem to be getting invoked. It was confusing.
OK. It is odd that the functionality was dropped. I think it is important to have such functionality. However, I am worried about losing the latest updates in the code. I don't suppose the serial port switching could be crafted back into the lastest? Also, I think there is a bit more complication to this. The console is not guaranteed to be on HBIOS unit Char 0. ZMP should use the current console unit for the console (which I think it should automatically) and then allow using any other port for communications. This means comparing the requested port with the current console unit and disallowing the use of the console unit. I can do this if you like.[/quote]
This is great work. Thanks Phil.
-Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9036 is a reply to message #9033] Sun, 22 August 2021 07:09 Go to previous messageGo to next message
b1ackmai1er wrote on Sun, 22 August 2021 03:46
Regards Phil.
No rush. Do you have any idea how much changed between these two versions?
-Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9037 is a reply to message #9032] Sun, 22 August 2021 07:13 Go to previous messageGo to next message
This is really testing my memory, but I thought I saw that there was a variant of ZMP that was specifically intended for "dial in" operation. This would mean that it would be launched from and use the console port. It would not require the second serial port.
Have you seen such a thing? I may go looking for it later. I assumed it used the same overlay structure, so would be easy to adapt your current work.
Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9038 is a reply to message #9037] Sun, 22 August 2021 09:37 Go to previous messageGo to next message
Thank you for working on this. I think ZMP will be a great addition to RomWBW and be a big help for a lot of RBC operators. Also if we're going to build ZMP using H-Tech C and adding it to RomWBW that's a double win. Very good news indeed! Congratulations on your success!
Yay! Thanks! Andrew Lynch
Re: xmodem-1K, ymodem, or zmodem [message #9039 is a reply to message #9037] Sun, 22 August 2021 11:56 Go to previous messageGo to next message
Wayne W wrote on Sun, 22 August 2021 08:13
Wayne
ZRC only has one serial port so I'm interested in the version of ZMP that use the console to transfer files. Since there are RC2014 users running ROMWBW with Z80, 68B50 and 512KRAM_ROM boards, ZMP that uses console is of interest to the RC2014 community. Having said that, I also have Z80+SIO+512KRAM_ROM setup to try out ZMP.
Re: xmodem-1K, ymodem, or zmodem [message #9040 is a reply to message #9037] Sun, 22 August 2021 22:37 Go to previous messageGo to next message
agn453 is currently offline  agn453
Wayne W wrote on Mon, 23 August 2021 00:13
Wayne,
My ancient memory was sparked...
The remote version of Ron Murray's Z-Modem was called RZMP - and it required BYE support.
You can find it on the Walnut Creek CD for CP/M - look for rzmp16.lbr
Tony
Tony Nicholson
Re: xmodem-1K, ymodem, or zmodem [message #9042 is a reply to message #9040] Mon, 23 August 2021 06:23 Go to previous messageGo to next message
Hi,
OK my memory is pretty rusty on this too. What is BYE support?
Re: xmodem-1K, ymodem, or zmodem [message #9043 is a reply to message #9042] Mon, 23 August 2021 11:10 Go to previous messageGo to next message
lynchaj wrote on Mon, 23 August 2021 06:23
Hi,
BYE is a pre-defined communications interface that was used by BBS software to interact with modems. You can think of it as a generic overlay. The interface extended BDOS with some calls that allowed direct interaction with communication ports/modems.
I think I looked into adding this to RomWBW at one point, but it was a bit more complex than just using an overlay for XModem, etc.
-Wayne
Re: xmodem-1K, ymodem, or zmodem [message #9044 is a reply to message #9043] Mon, 23 August 2021 11:32 Go to previous messageGo to next message
Thanks!
Re: xmodem-1K, ymodem, or zmodem [message #9191 is a reply to message #9040] Tue, 12 October 2021 04:13 Go to previous messageGo to next message
agn453 wrote on Mon, 23 August 2021 01:37
Wayne,
Tony
Has anyone tried RZMP on CP/M? If so, how did it work? Here is a link for the library file
http://www.retroarchive.org/cpm/cdrom/JSAGE/ZNODE3/MODEM/RZM P16.LBR
Re: xmodem-1K, ymodem, or zmodem [message #9192 is a reply to message #8912] Tue, 12 October 2021 04:27 Go to previous message
edzard wrote on Wed, 28 July 2021 11:11
Hello Andrew,
Best regards,
Edzard
Has anyone used this USB FIFO board? What was the transfer speed given all the other constraints of the system such as software, hardware, etc.? The wiki says it is an 8 bit clean path and ignores UART settings. Does anyone know what are the actual transfer speeds? I presume it is much faster than 9600 bps.
I am wondering if this board or something similar to it should be ported to the Z80 MBC system and if it would be better than existing solutions.
Previous Topic: Simple80, a low-cost, glue-less CP/M Ready Z80 SBC
Next Topic: TL866II+ minipro update.dat?
Current Time: Wed May 14 11:43:24 PDT 2025
Total time taken to generate the page: 0.00742 seconds
