Home » RBC Forums » General Discussion » Z80 16 bit i/o (Input & Output 16 bit data)
Z80 16 bit i/o [message #8351] Thu, 25 February 2021 06:51 Go to next message
Hello,
I was wondering if the capability of the Z80 to use a 16 bit i/o address can be used output a 16 bit data value, like this?
/forum/index.php?t=getfile&id=1993&private=0
  • Attachment: Z8016BIT.png
    (Size: 17.63KB, Downloaded 689 times)
Re: Z80 16 bit i/o [message #8352 is a reply to message #8351] Thu, 25 February 2021 07:06 Go to previous messageGo to next message
wsm is currently offline  wsm
The short answer is YES, although the instruction is actually "OUT (C),A". Since the actions are fully specified, the Z80 and derivatives actually supply a 16-bit I/O address.
This also works on other members of the Z80 family like the Z180 and eZ80. More importantly some of these other processors require A15-A8 = 0 for internal I/O devices and thus added the IN0 and OUT0 instructions. Zilog's ZDS actually accepts the "OUT (BC),r" form.
Re: Z80 16 bit i/o [message #8353 is a reply to message #8352] Thu, 25 February 2021 10:10 Go to previous messageGo to next message
cmacarthur is currently offline  cmacarthur
YES,
You can check out some of Alan's 16 bit I/O z80 boards for the RC2014,
https://hackaday.io/EtchedPixels
https://hackaday.io/project/168355-rc2014-bus-extender
https://hackaday.io/project/170819-16c552-dual-uart-for-rc20 14
They Work GREAT...
you just load BC with 16 bit I/O port address
then out (C),A or whatever register has data byte in it...
The issue is that once you start using/decoding 16 bit I/O, all programs and boards must be changed to 16 bit...
This includes your OS (CP/M etc)
Alan's boards above get around this by only having 1 8 bit I/O location that uses 16 bit addressing...
He swaps the HIGH and LOW bytes on the board (A0-A7 are now high and A8-A15 are now low)...
This also works great for INI,INDR,INIR,OTDR,OTIR,OUTD,OUTI as the "B" reg is INC or DEC giving you block I/O through one 8bit I/O location...
THX
CM
Re: Z80 16 bit i/o [message #8357 is a reply to message #8353] Fri, 26 February 2021 01:24 Go to previous messageGo to next message
Thank you. I am keen to try this out Smile
Re: Z80 16 bit i/o [message #8358 is a reply to message #8353] Fri, 26 February 2021 07:57 Go to previous messageGo to next message
hperaza is currently offline  hperaza
cmacarthur wrote on Thu, 25 February 2021 10:10
I think b1ackmai1er meant 16-bit data I/O and not 16-bit addressing of I/O ports. An interesting idea, that according to his diagram works by redirecting the high I/O address byte to the high data byte of the 16-bit I/O device, and leaving the low address byte for the usual 8-bit I/O port addressing. The only limitation is that it will work only for the output operation; input on the Z-80 is still limited to 8-bits.
Re: Z80 16 bit i/o [message #8365 is a reply to message #8358] Mon, 01 March 2021 07:48 Go to previous message
Sorry Missed that...
YES
The above diagram works great for Output as the high data byte is in the "B" reg
CM
Previous Topic: Question 1Mbx8 Flash/EEPROM
Next Topic: A new version of the S100Computers Serial IO Board
Current Time: Mon Mar 24 23:14:12 PDT 2025
Total time taken to generate the page: 0.03985 seconds
