Home » RBC Forums » General Discussion » New Board Development - SBC6120-RBC Edition
Re: New Board Development - SBC6120-RBC Edition [message #5237 is a reply to message #5236] Sat, 29 September 2018 14:37 Go to previous messageGo to next message
boss is currently offline  boss
For me as well.
Re: New Board Development - SBC6120-RBC Edition [message #5246 is a reply to message #5237] Sun, 30 September 2018 10:49 Go to previous messageGo to next message
I started a new thread on a simple Arduino checker to see if a chip is actually an HD1-6120:
https://www.retrobrewcomputers.org/forum/index.php?t=msg& ;th=328&start=0&
Re: New Board Development - SBC6120-RBC Edition [message #5308 is a reply to message #5246] Wed, 10 October 2018 14:22 Go to previous messageGo to next message
Picked up 2 more HD-6120's from UTSOURCE. They were listed as D1-6120-9C
https://www.utsource.net/itm/p/1887077.html
They appear old (some oxidation on pins, minor chips in ceramic) but original and both work perfectly.
$14.19 each, and they list 75653 in stock!!!
- Gary
Re: New Board Development - SBC6120-RBC Edition [message #5313 is a reply to message #4011] Thu, 11 October 2018 14:44 Go to previous messageGo to next message
will wrote on Tue, 26 December 2017 13:58
I measured the power consumption of my SBC6120, including IDE to CF adapter and CF card, as about 200mA. USB can easily deliver this.
Thanks for this. I may have to try it, as my recently-built SBC6120-RBC Edition successfully goes through POST but doesn't get to kick anything out the serial port. I suspect I may have fouled up the cabling. Or not found a terminal under Linux that can talk 7M1. 9-pin serial null-modems are much rarer beast these days than when the original SBC6120 came out.
One caveat about using FTDIs and the like is that - while USB can deliver 200 mA and beyond - they often negotiate to limit themselves to 100 mA. There's a milliamp rating (sometimes confusingly called "Max Power") in the USB parameters that shows you their current limit. SparkFun has a "Beefy" USB serial adapter that can deliver quite a bit more power, but is a lot more expensive.
Re: New Board Development - SBC6120-RBC Edition [message #5314 is a reply to message #5313] Thu, 11 October 2018 15:40 Go to previous messageGo to next message
FWIW, I found that simply doing 'screen /dev/ttyUSB0 9600' (or whatever your usb serial port is called) works. Of course, this was after I had spent some time trying to get usb-to-ttl adapters working (blush)...
Re: New Board Development - SBC6120-RBC Edition [message #5315 is a reply to message #5314] Thu, 11 October 2018 20:40 Go to previous messageGo to next message
Aha! The null modem cable I bought turned out to be straight-through. On rectifying, the console message came through. Yeah! Another successful SBC6120-RBC is built!
Re: New Board Development - SBC6120-RBC Edition [message #5320 is a reply to message #5315] Sat, 13 October 2018 12:50 Go to previous messageGo to next message
... though I shouldn't be too happy as I'm yet to get the thing to boot successfully.
I typically get the monitor prompt, but (B) isn't accepted:
SBC6120 ROM Monitor V320 Checksum 3752 6072 3515 09-APR-10 21:15:39
Copyright (C) 1983-2010 by Spare Time Gizmos. All rights reserved.
NVR: Not detected
IDE: 489MB - LEXAR ATA FLASH
IOB: Not detected
>BBBBBBBBB
This is just from pressing B once.
I did get a card to boot once, but unfortunately my serial params were wrong and all I got was noise
Are there any hints for troubleshooting booting, please?
Re: New Board Development - SBC6120-RBC Edition [message #5321 is a reply to message #5320] Sat, 13 October 2018 12:57 Go to previous messageGo to next message
Seems like you might still have some kind of a serial problem?
If you boot without the flash card attached, and type 'h <enter>' at the prompt, do you get the monitor ROM help?
Can you dump RAM, 'e 0000-1000 <enter>'
Re: New Board Development - SBC6120-RBC Edition [message #5322 is a reply to message #5321] Sat, 13 October 2018 14:40 Go to previous messageGo to next message
I had a problem with keys repeating - they would just repeat until the monitor's input buffer was full. It turned out that the GAL at U11 was not programmed correctly (or it was a faulty chip). I swapped in a newly programmed replacement GAL at U11 and the issue went away.
Re: New Board Development - SBC6120-RBC Edition [message #5323 is a reply to message #5322] Sat, 13 October 2018 15:03 Go to previous messageGo to next message
These GALs came from one of my wait list kits, so they were tested to boot & run Adventure off a CF card before being sent out. Not that there couldn't be a problem, but it would be the first I'd heard of with any of the kits or partial kits that I've sent out.
I have found that some of my CF cards are sensitive to the duration of the reset pulse and holding down the reset button for longer makes them come up. But I'd definitely recommend testing without the CF card first to make sure the monitor is running properly. (The monitor is pretty smart, when you ask for help for instance it only shows the IDE commands if there is an IDE drive detected!Wink
Re: New Board Development - SBC6120-RBC Edition [message #5324 is a reply to message #5323] Sun, 14 October 2018 01:34 Go to previous messageGo to next message
Simmo is currently offline  Simmo
Yeah, I picked up a D1-6120-9C ($AUD17) and a HD3-6402R-9 ($AUD4.50) from UT Source which look OK. Hopefully they work. Yet to get myself a PCB, which I'll get shortly from Andrew B, and test these chips. Looking forward to a PDP adventure game myself.
Andrew B, let us know through the boardinventory page what you have left available for the SBC6120-RBC.
Simmo
Re: New Board Development - SBC6120-RBC Edition [message #5325 is a reply to message #5324] Sun, 14 October 2018 15:07 Go to previous messageGo to next message
So - there have been a few people who have been waiting a long while for 'wait list' stuff. Apologies to the people who have patiently waited. I hate to take any $$ unless I know I can ship promptly, so it's been slow going since I made the giant bath of 65 original kits. I'm ordering some GALs + EEPROMs to get caught up along with more PCBs. I have a few tested 6120s left but based on the wait list I have, I believe that they are all likely spoken for at this point. If I get through the list and any are left, I'll post back here.
The mis-numbered D1-6120 from UTSource seems like a good option right now.
[Updated on: Sun, 14 October 2018 15:07]
Re: New Board Development - SBC6120-RBC Edition [message #5327 is a reply to message #5321] Mon, 15 October 2018 09:48 Go to previous messageGo to next message
Andrew B wrote on Sat, 13 October 2018 15:57
Can't seem to do either. Entering 'H<cr><lf>' at the prompt usually returns a <lf>. This last time I've tried it, all three POST lights lit up and it seems to have hung.
(I'd be happy to start another thread about this, as my serial issues must be tedious for other readers.Wink
What I've tried/tested:
  • two different null modem cables
  • two different serial adapters
  • continuity between 6402 and MAX232: good
  • continuity between MAX232 and serial out: good
  • capacitors on MAX232 are all good
  • Replacing the MAX232 with a socket and USB serial adapter resulted in all three POST bits lit and no useful function
  • reset button often doesn't work, even if held for a long time and no CF2IDE adapter present. Usually resets to just power LED and no POST
  • both oscillators doing their job (or there would be no coherent monitor message)
  • no obvious bent pins or shorts in the dual-wipe sockets
  • I have been more careful with ESD precautions with this build than any other, given the dire warnings in the manual
  • The board was less compatible with my lead-free + no-clean flux soldering setup than I'd hoped
  • (smallest CF I current have is 512 MB, and written using Etcher; I'm getting smallest cards I could find by mail this week)
Guess I'll have to trace every line and see if something's not connected.
Re: New Board Development - SBC6120-RBC Edition [message #5336 is a reply to message #5327] Mon, 15 October 2018 20:02 Go to previous messageGo to next message
It sounds like you're getting to the end of all of the logical things to do.
Did you happen to substitute any of the 7400 series logic with a different series compared to what is in the BOM? We had strange intermittent issues with some 74ACT (I think?) chips on the Rev 0.99 board, but I went to thicker power & GND traces + 2 Oz copper on the Rev 1.xx boards and that seemed to resolve that issue, even the previously problematic chips worked fine.
Where did you source the rest of the chips for the build?
I don't mind if we stay in this thread or split it off, totally up to you.
[Updated on: Mon, 15 October 2018 20:03]
Re: New Board Development - SBC6120-RBC Edition [message #5343 is a reply to message #5336] Wed, 17 October 2018 05:37 Go to previous messageGo to next message
All my logic chips are TI SN74HC... types, bought new from Digikey using your BOM generator, like all the other chips. I did find one dry joint on the low EEPROM, but fixing that made no difference. I may try the simple expedient of taking all the chips out and re-socketing them.
After that, I guess I'll have to test the logic chips one by one.
Re: New Board Development - SBC6120-RBC Edition [message #5375 is a reply to message #5343] Sat, 20 October 2018 20:41 Go to previous messageGo to next message
Reseated the chips ... and I don't even get POST any more ☹
Is there a way to get a nice connection table (basically a text version of the schematic, showing U1 P1 going to ___, U1 P2 going to ___, etc) from kicad? The schematics would be so much page flipping.
Re: New Board Development - SBC6120-RBC Edition [message #5376 is a reply to message #5375] Sat, 20 October 2018 20:52 Go to previous messageGo to next message
There should be a text file of the netlist in the .zip with the Gerber & KiCAD files. Take a look at SBC6120-RBC.net, in the bottom of the file all of the nets are listed.
If you want to post or send some pictures of the board, I'll take a look to see if there is anything amiss.
Re: New Board Development - SBC6120-RBC Edition [message #5388 is a reply to message #5376] Mon, 22 October 2018 15:00 Go to previous messageGo to next message
Thanks, Andrew. I managed to generate a sorted by component netlist using kinparse - https://github.com/xesscorp/kinparse .
Photos are here:
I fear I may have burnt off a couple of pads, so as long as there aren't too many I might be able to use patch wires. If not, I may have to come back to you for a new board.
Re: New Board Development - SBC6120-RBC Edition [message #7515 is a reply to message #5388] Mon, 13 April 2020 18:51 Go to previous messageGo to next message
Wheee! I finally got this rebuilt and tested: thanks for sending those boards, Andrew!
I'm still getting no keyboard response at the monitor:
NVR: Not detected
IDE: Not detected
IOB: Not detected
>H
But at lest the thing's not fried due to my terrible soldering last time!
Re: New Board Development - SBC6120-RBC Edition [message #7518 is a reply to message #7515] Tue, 14 April 2020 03:14 Go to previous messageGo to next message
Check hardware (RTS/CTS or DSR/DTR) flow control is disabled on your serial terminal (otherwise it may not transmit).
Pin 19 (DR) on the UART (U16) should go high when there is a character received and waiting for the PDP-8 to read out, and stay high until pin 18 (/DRR) on the same chip goes low.
These signals are both connected to IOT2 (U11) so check this chip is correctly programmed if the DR signal is apparently being ignored or /DRR is not being generated.
Re: New Board Development - SBC6120-RBC Edition [message #7520 is a reply to message #7518] Tue, 14 April 2020 06:06 Go to previous messageGo to next message
Not to suggest the most simple possiblility, but are you using 9600 baud, 7 bits, mark parity and 1 stop bit?
- Gary
Re: New Board Development - SBC6120-RBC Edition [message #7525 is a reply to message #7520] Tue, 14 April 2020 16:09 Go to previous message
Thanks! Caught the problem on the first elimination: the USB-Serial null-modem combo was wired wrongly. Swapping it for the one on my Zeta2 made it happy.
[Updated on: Tue, 14 April 2020 16:17]
Previous Topic: Anyone here attracted to Magnetic Bubble Memory?
Next Topic: uClinux running on a 68008 board
Current Time: Mon Aug 03 02:42:22 PDT 2020
Total time taken to generate the page: 0.01530 seconds
