Home » RBC Forums » General Discussion » ZRCC, Z80+RAM+CPLD+Compact Flash (Z80 SBC)
Re: ZRCC, Z80+RAM+CPLD+Compact Flash [message #7953 is a reply to message #7695] Tue, 08 September 2020 16:17 Go to previous messageGo to next message
What has started out as discovery of a forgotten batch of fast RAM and my desire to check the design margin of ZRCC are becoming a long exercise in Z80 overclocking. RAM speed was the first limit, but at 30MHz or greater, the CF disk becomes the limit. This is what a 33MHz ZRCC looks like after 2 iteration of pc boards. The 25ns 128KB RAM is fast enough for Z80 to run zero wait state at 33MHz and replacing CF disk with disk-on-module also allow zero wait access of the mass storage. The pc board is 2-layer, 50mm X 76mm.
To verify the board really work at 33MHz, I run memory diagnostic, run CP/M, do disk copy with verify in CP/M, and run the instruction test zexall.com. 4 out of 5 boards passed at 33MHz. The 5th board failed zexall.com tests. Once the Z80 of the 5th board is replaced with another, it passed all tests at 33MHz. So I think I've reached speed limit of Z80.
Power consumption is 160mA at 5V.
https://www.retrobrewcomputers.org/doku.php?id=builderpages: plasmo:zrcc:zrcc1_3
/forum/index.php?t=getfile&id=1843&private=0
[Updated on: Tue, 08 September 2020 16:20]
Re: ZRCC, Z80+RAM+CPLD+Compact Flash [message #7985 is a reply to message #7953] Fri, 25 September 2020 10:48 Go to previous messageGo to next message
jaevans is currently offline  jaevans
Hopefully, this is an appropriate question for this thread.
I am trying to transfer files through Teraterm to the ZRCC but have not gotten xmodem on the ZRCC (in either CP/M 2.2 or 3.0) and xmodem through Teraterm by manually typing the commands to transfer a file. If I create a macro file similar to the newCF.ttl file to transfer a simple small text file, the transfer succeeds.
So, I am looking for help in using xmodem on the ZRCC to transfer files to the drives.
Thanks in advance.
John - Colorado Springs, CO
[Updated on: Fri, 25 September 2020 10:50]
Re: ZRCC, Z80+RAM+CPLD+Compact Flash [message #7986 is a reply to message #7985] Fri, 25 September 2020 12:49 Go to previous messageGo to next message
John,
22 MHz Z80 does not allow much time to search for files. So put your files to be transferred in TeraTerm default directory and use this XMODEM option to give you maximum amount of delay:
XMODEM filename /r/z1
Be quick about it, you have very little time to look for file. Good luck!
Re: ZRCC, Z80+RAM+CPLD+Compact Flash [message #7987 is a reply to message #7986] Fri, 25 September 2020 19:57 Go to previous messageGo to next message
HA, that did it. Thanks.
plasmo wrote on Fri, 25 September 2020 12:49
John,
Re: ZRCC, Z80+RAM+CPLD+Compact Flash [message #8210 is a reply to message #7987] Tue, 19 January 2021 17:35 Go to previous message
As mentioned in the original post, some 20MHz Z80 can run to 33MHz, but as I lowered the supply voltage toward 4.75V, fewer and fewer Z80 can pass memory test, CP/M disk copy, and zexall instruction test at 33MHz. Roughly 10% is good to 33MHz at 4.75V. However, at 29.5MHz about 9 out of 10 Z80 are good. Because I believe 29.5MHz ZRCC is producible, I have added a new section of software in ZRCC v1.3 homepage specifically for 29.5MHz as well as automated software installation. I also listed the testing procedures to verify proper operation.
https://www.retrobrewcomputers.org/doku.php?id=builderpages: plasmo:zrcc:zrcc1_3#software_for_295mhz_clock
PS, I have built up all ten rev 1.3 boards and auction them off on eBay starting from $1; one a week until they are all gone. They are selling well, but you guys know how to order the pc board and build them yourselves. I'm happy to help you with construction and debugging if you've ran into problems.
Previous Topic: Sipix pocket printer
Next Topic: 80-column video options for RC2014 15KHz
Current Time: Mon Mar 24 22:58:09 PDT 2025
Total time taken to generate the page: 0.03655 seconds
