Home » RBC Forums » General Discussion » Z80 IFF1 default at RESET
Z80 IFF1 default at RESET [message #6086] Mon, 11 March 2019 18:46 Go to next message
alank2 is currently offline  alank2
After releasing /RESET the interrupt mode=0, but what about the IFF1 and IFF2 flags? Are they reset to disabled/0?
If so, how can control panels feed something like a JMP instruction? I know I could put that at bytes 0, 1, and 2 in memory, but I was hoping to change the PC after releasing reset.
Re: Z80 IFF1 default at RESET [message #6087 is a reply to message #6086] Mon, 11 March 2019 19:33 Go to previous messageGo to next message
wsm is currently offline  wsm
The Z80 User Manual clearly states that upon RESET IEF1 and IEF2 are both zero (i.e. interrupts masked just like DI) and the Mode is set to 0.
As I remember, some of the panels used the trick of inhibiting the data bus and just supplying NOPs (i.e. opcode 00) until the restart address was reached at which time normal memory fetches occurred. The other option was to also inhibit the data bus but respond to the first memory read after RESET with a JMP (opcode 0C3h) followed by responses of the actual execution address (N.B. little endian).
Re: Z80 IFF1 default at RESET [message #6088 is a reply to message #6087] Mon, 11 March 2019 19:39 Go to previous messageGo to next message
Thanks wsm, that second method sounds like it will work well.
Re: Z80 IFF1 default at RESET [message #6091 is a reply to message #6088] Tue, 12 March 2019 04:42 Go to previous messageGo to next message
The magic words for the above in the S100 world were "power on jump": there's a modern example at http://www.glitchwrks.com/2013/04/17/power-on-jump.
Re: Z80 IFF1 default at RESET [message #6092 is a reply to message #6091] Tue, 12 March 2019 04:58 Go to previous message
Indeed; excellent link I enjoyed seeing how it would be done in hardware. I did something similar in software last night. (/SRDBL disables SRAM from responding even if /MREQ is asserted)
    //assert srdbl (we want to feed a jmp instruction)
    PORTJ&=~_BV(PORTJ_SRDBL_PIN_AL);
    //data bus output
    DDRA=0xff;
    //jmp opcode
    PORTA=0xc3;
    //assert busrq
    PORTG&=~_BV(PORTG_BUSRQ_PIN_AL);
    //release z80
    PORTG|=_BV(PORTG_RESET_PIN_AL);
    //wait for asserted busack
    while (PING & _BV(PORTG_BUSACK_PIN_AL))
    //low byte address
    PORTA=0x11;
    //release busrq
    PORTG|=_BV(PORTG_BUSRQ_PIN_AL);
    //assert busrq
    //high byte address
    PORTA=0x22;
    //release busrq
    //assert busrq
    //data bus input
    DDRA=0;
    PORTA=0;
    //deassert srdbl
    PORTJ|=_BV(PORTJ_SRDBL_PIN_AL);
    //release busrq
[Updated on: Tue, 12 March 2019 04:58]
Previous Topic: Building a 22MHz Z80 Computer in 4 Stages
Next Topic: Any Interest in OS9 68K
Current Time: Tue May 14 22:57:46 PDT 2024
Total time taken to generate the page: 0.00681 seconds
