Home » RBC Forums » General Discussion » Multicomp 6809 and the Serial Ports
Multicomp 6809 and the Serial Ports [message #6023] |
Wed, 27 February 2019 11:58  |
coolbear
Messages: 15 Registered: February 2019
I recently assembled a Multicomp II board and have it configured as a 6809. My interests are with Nitros9. I'm using the first serial port as the console and right now, I'm trying to get the second serial port working as..., well as a second serial port.
First question - I see that there are three serial port device descriptors included in the Nitros9 image. Am I correct in assuming that the console is /TERM and serial B is /T0?
Second question - I'm not seeing anything coming out of the second serial port (Serial B). I see that the status register on all three ports (0xFFD0/0xFFD2/0xFFD4) is 0x02, which means that TDRE is set and I should be able to transmit. If I write a hex value to 0XFFD1, I see that character appear on the console. If I write to 0XFFD3 or 0XFFD5, I get nothing on the second serial port.
I'm wondering if that as because while there are three 6850s defined in the FPGA but perhaps the I/O from the second or third 6850 is not brought out to the connector. Clearly, one of the three is not brought out because there are only two serial presences on the PCB.
Any ideas?
Re: Multicomp 6809 and the Serial Ports [message #6028 is a reply to message #6026] |
Fri, 01 March 2019 12:45   |
nealcrook
Messages: 127 Registered: October 2015 Location: UK
I think that, to enlarge DD, you would either need to rebuild from source or use the toolshed tools to create a larger empty disk image and then copy everything from the existing boot disk onto it.
Next, you need to change the script that creates the SDcard image so that it will insert this new, larger image without overwriting the other disk images
Finally, you need to change the Nitros drive "descriptors" to understand the new SDcard block start address associated with the new (more widely-spaced) disks. You can hack them or rebuild from source. From level2/mc09l2/modules/makefile:
# SDOFFSET is the high 16 bits of the 24-bit block address at
# which the disk image starts on the SDcard. It must match
# the value used in the create_sd_image script.
dds0_80d.dd: mc09sdcdesc.asm
$(AS) $< $(ASOUT)$@ $(AFLAGS) $(DSDD80) -DDNum=0 -DSDOFFSET=0x0280 -DDD=1
s1_80d.dd: mc09sdcdesc.asm
$(AS) $< $(ASOUT)$@ $(AFLAGS) $(DSDD80) -DDNum=1 -DSDOFFSET=0x0290
s2_80d.dd: mc09sdcdesc.asm
$(AS) $< $(ASOUT)$@ $(AFLAGS) $(DSDD80) -DDNum=2 -DSDOFFSET=0x02A0
s3_80d.dd: mc09sdcdesc.asm
$(AS) $< $(ASOUT)$@ $(AFLAGS) $(DSDD80) -DDNum=3 -DSDOFFSET=0x02B0
I don't know your level of familiarity with all this stuff so let me know if you need help or more detailed pointers. A simpler (though not so convenient) approach is to make the 4th disk larger - you can do this without trampling on any of the others or changing and start addresses.
Using the L2 image there is at least some indication that the serial ports should work. Specifically, in my emulator, which is using the "vdu" as /term, I confirmed that you should be seeing output on /t1. I assume that you're using (level2) from my SDcard image on the WIKI?
$ ./mc09-run-int
Reading symbols from '../6809M.map'...
02:0x1F7E 8606 LDA #$06
(dbg) c
6809 CamelForth v1.1 20 Mar 16
OK NITROS9 NITROS9 BOOTKREL Boot Krn tb0...........................................................................................bKrnP2 IOMan Init RBF mc09sd DD D0 D1 D2 D3 SCF mc6850 Term T0 T1 PipeMan Piper Pipe Clock Clock2 Shell Date DeIniz Echo Iniz Link Load Save Unlink i2xo[uart0 stat wr: PC=0xc59d, addr=0x0000, w data=0x82]
CNitrOS-9/6809 Level 2 V3.3.0
Multicomp09
(C) 2014 The NitrOS-9 Project
** DEVELOPMENT BUILD **
** NOT FOR DISTRIBUTION! **
Fri Jun 9 20:13:12 2017
http://www.nitros9.org
* Welcome to NitrOS-9 Level 2 on the Multicomp09 *
yyyy/mm/dd hh:mm:ss
Time ?
June 09, 2017 20:16:42
Shell+ v2.2a 17/06/09 20:16:58
{Term|02}/DD:echo hello >/term
hello
{Term|02}/DD:echo hello >/t0
[uart1 stat rd addr=0x00000002]
[uart1 stat wr: PC=0xc59d, addr=0x0002, wdata=0x83]
[uart1 data wr of 0x68]
[uart1 data wr of 0x65]
[uart1 data wr of 0x6c]
[uart1 data wr of 0x6f]
[uart1 data wr of 0x20]
[uart1 data wr of 0x0d]
[uart1 data wr of 0x0a]
{Term|02}/DD:echo hello >/t1
[uart2 stat rd addr=0x00000004]
[uart2 stat wr: PC=0xc59d, addr=0x0004, wdata=0x83]
[uart2 data wr of 0x68]
[uart2 data wr of 0x65]
[uart2 data wr of 0x6c]
[uart2 data wr of 0x6f]
[uart2 data wr of 0x20]
[uart2 data wr of 0x0d]
[uart2 data wr of 0x0a]
{Term|02}/DD:
Although I did both the Level 1 and Level 2 OS ports I actually have very limited expertese in NitrOS-9 so if you want to create an application disk image or some user notes or point out some bugs I'd welcome your contribution. It might even motivate me to tidy up some of the documentation and build notes on the WIKI and my Github WIKI
Yes, 25MHz 6809 is neat! Others have this design going even faster
Neal.
Re: Multicomp 6809 and the Serial Ports [message #7625 is a reply to message #7622] |
Sun, 10 May 2020 17:41  |
computerdoc
Messages: 130 Registered: October 2015
Hi David,
Neal just reminded me what needs to be done to increase the online storage on the SD Card for NitrOS9. Then I realized what I did to
create the 4 - 1GB partitions for the Coco3FPGA which is very different from what is needed on the Multicomp09 v1.10 board SD card
setup which is the last version of the Multicomp09 board that I built.
The SD Card setup for the Coco3FPGA has only 1 NitrOS9 Operating system with 4 - 2MB disk drives so there are no other software systems
to be concerned about getting overwritten when enlarging the 4 disk descriptors to create larger disk drive images on the SDHC card.
Whereas, the Multicomp09 SD card has 7 different software packages / operating systems specifically placed on that SD card which are
Camelforth, Microsoft Extended Color Basic, Flex09, Buggy - a 6809 monitor with among other things an inline assembler / disassembler,
Cubix, NitrOS9 and Fuzix. These 7 software systems are located on the SD Card in that specific order.
As you know, the Multicomp09 at power-on boots into Camelforth 1st. From Camelforth, the other 6 software packages / operating systems
can be called using 1 of 6 key words specifically written to transfer control of the Multicomp09 to 1 of the other 6 software systems.
To enlarge the 4 Disk Drive Images in NitrOS9, new locations for the 2nd, 3rd and 4th drives must be calculated so the 2nd, 3rd and 4th
Disk Descriptors and the build scripts both can be updated with the new calculated locations. In addition, new updated and resized disk
drive image files have to be created corresponding to each of the 4 disk descriptors.
So what I need to do, is revisit the Multicomp09 build scripts to make sure I'm remembering all this correctly and begin making the
calculations. Many steps are needed to be updated to make sure the larger disk images are in the correct places on the SDHC card where
the updated Disk Descriptors expect them to be.
In addition to all that, Fuzix has to be moved further into the SD card so it does not overwrite the new resized NitrOS9 disk drive
images previously written by the build scripts as Fuzix is the last operating system to be written to the SDHC card when the build
scripts are executed. Remember, the 4 resized disk drive image files have to be created for NitrOS9 before the build scripts can be run.
Please give me some time to work this long process into my daily life which has also changed considerably since my Multicomp09 days.
I will need to know what new size you desire for the 4 disk drives in NitrOS9. I may need other information as the process progresses.
In answer to your request, the last version of "Preparing Terasic DE-1 & SD Card for Self-booting NitrOS-9.pdf" for the Coco3FPGA I wrote
is attached for you to peruse and enjoy.
Note: Please do NOT use this setup guide unless you have a fully functional Coco3FPGA platform.
This is just to give you some idea of what is involved with a portion of the process to enlarge the 4 NitrOS9 disk drives. Once the new SD
card image is built, I will get back to you.
Oh, by the way, I will need to know what additional software you wish to have on the 2nd, 3rd and 4th disk drives in NitrOS9. As there is no
way to connect to the internet in this version of NitrOS9, to add, change or update any of the software packages on the 4 disk drive images
as of the last time I used my Multicomp09 boards, is to recreate the 4 disk drives' image files and rebuild the SD card image file.
I remember having a lot of fun working with Neal during the development process and testing of the Multicomp09 hardware as well the software.
Fell free to ask questions any time. Well, that is all I have for the moment. Take care my friend!
Kip
Kip Koon
Current Time: Wed Apr 30 09:25:58 PDT 2025
Total time taken to generate the page: 0.00844 seconds
