Home » RBC Forums » General Discussion » Multicomp with native b/w graphic (640x240px graphic extension with progr. font-ROM)
Multicomp with native b/w graphic [message #5967] Mon, 18 February 2019 11:12 Go to next message
kman is currently offline  kman
Hi folks,
I've given Multicomp a native graphics screen with 640x240px including a fully programmable font-ROM. For more information see my builderpage 'muellerk' in the forum wiki.
cheers
Kurt
Re: Multicomp with native b/w graphic [message #5969 is a reply to message #5967] Mon, 18 February 2019 23:56 Go to previous messageGo to next message
Great!!! You are pulling me to do a Cyclone IV version of "The Thing" soon ... Laughing
At this point I'll see if can be possible to leave the option to use a EP4CE15E22C8N or a EP4CE22E22C8N too...
UPDATE: the EP4C6 has 91 IO pins, the EP4C15 81, the EP4C22 79.... hmmm...
UPDATE2: the EP4CE10E22C8N has 91 IO pins too, so may be it is an easier upgrade...
[Updated on: Tue, 19 February 2019 06:02]
Re: Multicomp with native b/w graphic [message #5972 is a reply to message #5967] Tue, 19 February 2019 06:12 Go to previous messageGo to next message
Nice work Kurt.
I have been hoping someone will do a Multicomp terminal. An ECB+Multicomp graphics terminal would be even better.
Regards Phil
[Updated on: Tue, 19 February 2019 06:14]
Re: Multicomp with native b/w graphic [message #5974 is a reply to message #5969] Tue, 19 February 2019 20:22 Go to previous messageGo to next message
Hi just4fun,
if you really start a new board design, consider the following:
b/w graphic is a ok, that needs in 640x480px 38.4kB RAM the EP4CE10E22C8N has that block-RAM internally.
But what I would prefer is 640x480px and 1 byte per pixel = 307200 Byte in a 2x2x2x2 (RxGxBxLumi)
configuration. That leads to an external SRAM of 512kB. Together with 1MB SRAM we already have, we end
up with a lot of pins. My second wish would be to interface to a RC2014 backplain. That are 40 pins+
cheers
Kurt
Re: Multicomp with native b/w graphic [message #5975 is a reply to message #5972] Tue, 19 February 2019 20:30 Go to previous messageGo to next message
Hi Phil,
yes, when I got my Multicomp up and running, it doesn't last very long until I decided that
a ASCII-Screen isn't enough. Grant's display solution is a little bit complicated. He sqeezed
a lot of functionality into his VHDL-code, but at the end I got it done.
cheers
Kurt
Re: Multicomp with native b/w graphic [message #6011 is a reply to message #5975] Sun, 24 February 2019 00:43 Go to previous messageGo to next message
JonB is currently offline  JonB
That font looks familiar... Smile
You say on your page that you are looking for a polygon fill. More often referred to as "food fill" - there are several ways to do it. When I was at college many years ago, I had a programming competition with a friend to produce a flood fill on a Sinclair Spectrum. Mine used the stack and couldn't flood fill really complex shapes like the background to a screen of text. His used a circular buffer and worked better. It was also much faster, although it took him 3 times as long to write.
Unfortunately, the source code was lost but I do have the prototypes in Spectrum BASIC.
[Updated on: Sun, 24 February 2019 00:43]
Re: Multicomp with native b/w graphic [message #6012 is a reply to message #6011] Sun, 24 February 2019 03:04 Go to previous messageGo to next message
http://www.retroprogramming.com/2017/04/zx-spectrum-scanline -flood-fill.html
Re: Multicomp with native b/w graphic [message #6013 is a reply to message #6011] Sun, 24 February 2019 05:12 Go to previous messageGo to next message
thank you for the hint. I will investigate that. I've found something in one of my old books (Franzis-Verlag, Juergen Plate, "Computer Graphic: ..."), a promising algorithm that can handle complex polygons to fill. That's what the paper says... When I've finished my ellipse challenge (the assembler code is written - incl. the needed 32-bit math, now I've to re-check and test the code).
At the moment I'm uncertain what to do next: go on with 'Flood-Fill' or splitt the RSX-Code into smaller peaces/files. The reason: I've several times accedently past/delete code when scrolling lines with the mouse wheel. On the other hand, I can do that later and go on...
Re: Multicomp with native b/w graphic [message #6017 is a reply to message #6013] Sun, 24 February 2019 13:06 Go to previous messageGo to next message
Flood fill and polygon fill are different things. Polygon fill works from the geometry and basically flips between fill/nonfill at each line crossing of the polygon border, whilst a floodfill like that linked to starts at a point and fills the enclosed space. They produce different results.
The spectrum flood fill given is ok but the better ones checked bytes and did other clever things. Without that flood fill tends to be really really slow. The pattern capable one in the Illustrator and PAWS is a really good example to study with a disassembler.
Re: Multicomp with native b/w graphic [message #6018 is a reply to message #6017] Sun, 24 February 2019 14:26 Go to previous messageGo to next message
Flood fill vs Polygon fill - true I hadnt thought of that distinction.
Re: Multicomp with native b/w graphic [message #6019 is a reply to message #5967] Mon, 25 February 2019 02:21 Go to previous messageGo to next message
never mind, I will try it. Otherwise I will stick to polygon fill. May be it's the better over all solution.
Re: Multicomp with native b/w graphic [message #6031 is a reply to message #6019] Sun, 03 March 2019 02:21 Go to previous messageGo to next message
Stumbled upon this arduino display library that may be useful as it has some bitmap polygon fill functions.
https://github.com/olikraus/u8g2/wiki/u8g2reference
Re: Multicomp with native b/w graphic [message #6032 is a reply to message #6031] Tue, 05 March 2019 03:09 Go to previous messageGo to next message
Thank you for the link. I've searched through the zip files and found a lot of interesting stuff...
Re: Multicomp with native b/w graphic [message #6133 is a reply to message #6032] Thu, 14 March 2019 13:40 Go to previous messageGo to next message
Hi all,
For those who own a multicomp-6809/6502 and wish to use my graphic-modification, I have incl. my last BASIC-Version of the graphic library I used to test the hardware attached for download. It has all line and text functions at the level when I started to code the CP/M3-RSX. It is pretty usable and fast when compiled with the CB80 BASIC-Compiler. The code is in plain ASCII
Re: Multicomp with native b/w graphic [message #6134 is a reply to message #6133] Thu, 14 March 2019 15:10 Go to previous messageGo to next message
Nice work, thanks for sharing your code. BASIC must still be the best tool for quick small utilities :)Might try and use some routines to do some graphics on the VDU board I just completed .. would be 160x72 pixels lol.
Can you please upload CP/M file in .ARC and/or .LBR format in future (joke!Wink.
Re: Multicomp with native b/w graphic [message #6139 is a reply to message #6134] Fri, 15 March 2019 03:19 Go to previous messageGo to next message
If the hack is not longer then ~100 lines basic is ok. But the lack of const definitions, real subroutines with local param a.s.o. makes it a pain, when the programm complexity reaches a certain state.
I've search my computer and found the last sample of my "GRAFTST.bas" that can handle 160x120px semi block-graphic (aka 80x30 ASCII-screen). It only handles pixels, no text output. I think that is more suitable to your 160x72px graphic, because the special address and pixel calc. is considered. You have to adjust only the lines where the calc. is done...
Re: Multicomp with native b/w graphic [message #6140 is a reply to message #6139] Fri, 15 March 2019 04:52 Go to previous messageGo to next message
Yes you are right. I never really got past ASM, BASIC and Turbo Pascal, little bit of Delphi. Can do basic stuff in C if forced to (arduino). I really liked Delphi but didn't get far with it.
Thanks for the code example.
Re: Multicomp with native b/w graphic [message #6192 is a reply to message #6140] Fri, 29 March 2019 04:50 Go to previous messageGo to next message
Short info regarding the promised ref-manual:
I'm midway writing it. It's difficult enough to write one in ones own lanbuage, but doing it in a foreign language is to combat a real beast...but it's not hopeless ;-) I think it will be ready within the next weeks. At the moment I can say, the software is fairly bugfree, nothing horrible found until now. Same to the graphic hardware. Every try to get it to stumble fails - but never ask the developer wether his work is stable/good. He will always say YES ! ;-)
Re: Multicomp with native b/w graphic [message #6193 is a reply to message #5967] Fri, 29 March 2019 06:01 Go to previous messageGo to next message
Love the Data 70 font.
Have to add on e to the ECB-VDU.
Regards Phil
Re: Multicomp with native b/w graphic [message #6195 is a reply to message #6193] Sat, 30 March 2019 17:41 Go to previous messageGo to next message
Sorry, I'm a little bit late, but we have some sunny days here and garden work is calling... ;-)
Some interessting fonts can be found here
Click on the font picture to download.
A usefull font-editor is here, I'm unsure, but it might be already mentioned elsewhere in the forum.
Start it twice for copying between fonts.
Re: Multicomp with native b/w graphic [message #6239 is a reply to message #6195] Fri, 12 April 2019 03:20 Go to previous messageGo to next message
I've uploaded a new xgraph-archive, incl. the hopefully final version (for the moment) of the xgraph package together with the ref-manual on my builder-page. I've shifted all functions that are more low-level from xdraw.h etc. into xsys.h. I think these functions are more less often used, so it's better to have them out of the way. There is also a new demo, that shows the data of the Ellipse-Struct. on the ASCII- and a FnRBoxEllipse sketch on the graphic-screen. If possible use a terminal-app on a PC and a 2nd monitor for the Multicomp-VGA output. This structure caused me some headache, because I've made a small but "hard to find" typo in a rightshift-subroutine that divided 2 WORD's by 2 at a unexpected place inside the struct (of cause only in one resolution mode). Sad This turned the graphic into a wood of lines, ggrrr.... The result of this bug-hunting is xdemo8. The output is more functional, don't expect a eye-candy..., there is some potential for improvements.
Re: Multicomp with native b/w graphic [message #6286 is a reply to message #6239] Fri, 10 May 2019 19:28 Go to previous messageGo to next message
Had this Cyclone IV sitting in my shopping cart for a long time and looks to be
in the Multicomp IV-B format.
Price has finally dropped if anyone else is interested.
Aliexpress
This ones a different format but looks like good value
As if I needed further distraction, doh!
Re: Multicomp with native b/w graphic [message #6287 is a reply to message #6286] Sat, 11 May 2019 00:47 Go to previous messageGo to next message
Very interesting board (EP4CE15F23C8N), especially the FPGA size and the 2.54mm pinheader with its 108 user I/O's, and the SDRAM. I've ordered one to test it. I've a small wish list for extending the 'old' Cyclone-IVb board by a interface to the RC2014 bus with a 'backplane' sitting on top of the FPGA-Board (for example), extra 512k VGA-RAM for full 640x480px graphics (may be with colour 2x2x2x2). There may be more..., so what about extending the 'old' Cyclone-IVb board ? Any thoughts about that ?
The Cyclone-IV board looks very similar to my blue spare one. The green board has a 50MHz oscillator instead of 25MHz as the blue one.
[Updated on: Sat, 11 May 2019 06:24]
Re: Multicomp with native b/w graphic [message #6628 is a reply to message #6287] Mon, 07 October 2019 02:03 Go to previous messageGo to next message
Hi Kurt,
How did you go with that Aliexpress board?
Regards Phil.
Re: Multicomp with native b/w graphic [message #6631 is a reply to message #6628] Mon, 07 October 2019 08:09 Go to previous messageGo to next message
Hi Phil,,
do you have a sixth sense for new things ? At present I'm testing a new Multicomp prototype board (I call it "Multicomp_CycloneIV-E_July2019") with the EP4CE15 Core Board from AliExpress. It's already runing with the VHDL-Code I used for the CycloneIVc board. The PCB is a little bit larger (160*132mm^2) then the old one. See the attached foto and component placement plot from kiCAD. When the final test of the i82C55A PIO is successful I intend to give the PCB-Layout to Aisler PB for a new set of PCB's (the prototype board has some bugs). At the end the whole project has of 3 PCB's: 1xMulticomp, 1xSiss-Pi Adapter and 1x2nd i82c55a PIO-Board. Important is only the Multicomp board ;-) , the other two PCB's are not mondatory if not needed.
A brief description of the new design is:
- 1 * the Cyclone IVc as the base design we already have
- 1 * stereo audio jack and a SN76489 sound chip with Delta-Sigma DAC (all in VHDL) - at present VHDL work in progress
- 1 * I2C Pin-Header with additional 2 * GPIO's, ment for connecting a SWISS-Pi Hat to this header. This allows
using most of the analog-I/O of the board, incl. the on-board-clock - at present VHDL work in progress
- 1 * PS/2 Mouse connector. CP/M dosn't know anything about a mouse, but other OS'es do...
- 1 * i82C55A PIO, with a header for a 2nd one.
- 1 * 40 Pin GPIO-Connector as on a DE1 board for actually unknown extensions...
- 1 * good reachable reset switch at the PCB border Smile
- 1 * 32MB 6ns SDRAM on the core board
There are a two +12V DC-Power Input jacks on the board. My 8" monitor needs +12V and this way I can chain all devices to one power supply. The +5V connector on the EP4CE15 board can be used for low power experimental things.
Kurt
[Updated on: Mon, 07 October 2019 10:25]
Re: Multicomp with native b/w graphic [message #6634 is a reply to message #6631] Mon, 07 October 2019 15:03 Go to previous messageGo to next message
Hi Kurt,
That looks great. I was playing with my Multicomp this weekend, which was what prompted me to ask. Installed your updated font.
Good to see a Multicomp update with through hole components.
Suggest adding space onboard 8 pin dip eeprom.
Adding a Pi Hat connector is a great idea!
Regards Phil.
Re: Multicomp with native b/w graphic [message #6635 is a reply to message #6634] Mon, 07 October 2019 17:38 Go to previous message
Hi Phil.,
there are no free pins to connect a eeprom to the FPGA, but if someone realy needs that, it's possible to use the one on the swiss-pi board (if used) or plug a small PCB with the eeprom into the pin-socket/ic-socket of serial-c (and unplug the MAX3232). There may be more solutions, but to re-open the layout is no good idea...
PS: I will try to add a 24LCxx type eeprom (DIP-8) to my swiss-pi adapter PCB.
cheers
Kurt
[Updated on: Tue, 29 October 2019 08:36]
Previous Topic: Snark Barker - PCBs and Components
Next Topic: New backplane for eurocard enclosure
Current Time: Thu Mar 28 22:03:31 PDT 2024
Total time taken to generate the page: 0.00866 seconds
