SD card socket for the Cyclone II v1.10 [solved] [message #3916] |
Sun, 10 December 2017 00:49 |
b1ackmai1er
Messages: 396 Registered: November 2017
Good Afternoon,
I am looking for a supplier for the SD CARD socket on the multicomp Cyclone II v1.10
Everthing I look at online seems to have different solder tab positions and pin positions.
Is anyone able to recommend a supplier and part number?
Also wouldn't mind the same for the RCA socket which seems to be different from current designs floating around.
Thank you.
[Updated on: Mon, 11 December 2017 04:42] Report message to a moderator
Re: SD card socket for the Cyclone II v1.10 [message #3928 is a reply to message #3924] |
Mon, 11 December 2017 04:25 |
b1ackmai1er
HI Guys,
PRT-12769 does look like a likely candidate, thank you.
I have soldered a sd card adapter to the board at present and all is working which I find rather astonishing.
Thanks for your documentation for the CPM install.
Regards Phil
