Home » RBC Forums » General Discussion » MSX Obsonet card technical data (looking for schematic)
MSX Obsonet card technical data [message #9575] Mon, 03 January 2022 05:37 Go to next message
Does anyone know where to find an archive copy of the Obsonet MSX Ethernet card?
http://obsonet.blogspot.com/2011/10/obsonet-v10.html
It was found here but when I click on the link for the hardware tech data it has since disappeared
http://www.sisembe.com/articulos/obsonetv1_files/obsonet_v1. tar.gz
I am thinking if we could replicate an RTL8019AS based Ethernet design with the network ROM it would reduce the new code needed
Most of the design is done already only the interface the network ROM remains
Re: MSX Obsonet card technical data [message #9583 is a reply to message #9575] Tue, 04 January 2022 07:38 Go to previous messageGo to next message
robg is currently offline  robg
Our own jordi.solis seems to have some Obsonet stuff here: https://github.com/msx-solis/Obsonet , including 'obsonet_v1(new).tar.gz' in the 'ficheros' subdirectory.
-- Rob
Re: MSX Obsonet card technical data [message #9584 is a reply to message #9583] Tue, 04 January 2022 08:51 Go to previous messageGo to next message
Hi Rob
Oh Wow! Ask and you shall receive! In KiCAD format no less! I was hoping for just fax quality scan and this is awesome!
THANK YOU! Andrew Lynch
PS, Jolis, you are great! Thank you so much!
Re: MSX Obsonet card technical data [message #9587 is a reply to message #9584] Wed, 05 January 2022 04:00 Go to previous messageGo to next message
OK, I looked over the Jolis github and it is good. It contains the KiCAD hardware tech data plus binaries for various software components. I think the source code can be found here:
https://github.com/Konamiman/MSX
So that helps for an MSX to CP/M port if that's a possibility
It's a good news story! Thanks, Andrew Lynch
Re: MSX Obsonet card technical data [message #10652 is a reply to message #9584] Wed, 03 April 2024 11:57 Go to previous messageGo to next message
jordi.solis is currently offline  jordi.solis
I had a previous design in an old version eagle format.
So that, the schematic may needs to be patched but let me check and improve the pcb.
Nice to ear that helped someone ;)
Re: MSX Obsonet card technical data [message #10653 is a reply to message #10652] Wed, 03 April 2024 12:53 Go to previous message
I've used the Obsonet info for an Ethernet board on nhyodyne but it never made it to production. Also transferred design over to duodyne for an Ethernet board. Still waiting to get to that particular board but it should be coming up soon.
Previous Topic: Baseboard for IP940, 68040 Mezzanine board
Next Topic: MSX single step
Current Time: Fri Mar 14 23:00:25 PDT 2025
Total time taken to generate the page: 0.00660 seconds
