Re: ECB enclosure ideas [message #10782 is a reply to message #10781] |
Sun, 19 May 2024 07:30   |
rcini
Messages: 64 Registered: October 2015 Location: Long Island, NY
I started from scratch using the Backplane 8 201506 version and just replaced the power connector and made other minor changes to support ATX power. There were problems manually routing the RESET signal to a new 2x4 "front panel" connector -- it wouldn't let me do it. Very strange, but after some poking around it has to do with both extra slashes in the net names and locked tracks -- there were several other signals with the same problem, I expect an artifact of using KiCAD 6 rather than what was originally used. Once I undid that, it worked. Attached is a revised plot.
The board is about 0.1" too tall for the case so the top will only be able to float on-top (or just leave it off). I thought about shrinking the backplane, but it wouldn't matter since all of the ECB cards adhere to the standard. So, it's a less-than-perfect solution but could provide stability and partial enclosure.
Rich
Rich Cini
[Updated on: Tue, 21 May 2024 05:54] Report message to a moderator
Re: ECB enclosure ideas [message #10806 is a reply to message #10782] |
Mon, 01 July 2024 07:47  |
rcini
I have not yet sent the modified backplane to manufacturing, opting instead to modify the design to use a spare backplane I had in stock. Here's the picture of the front of the setup. The ATX power board is on the right by the empty slot. The black strip on the bottom is a thin stick-on piece of neoprene to act as a way to prevent the boards from moving around a lot. The board stack is slightly taller than the case allows, so there's an opportunity to build a custom top out of acrylic or wood, maybe with some grooves to support the top of the board.
For those interested, it's an SBC-188 stack including my 4PIO, the CPU, 4MB memory, SD/Floppy, and 2S+1P cards.
Enjoy!
Rich
Attachment: IMG_4121.jpg
(Size: 2.36MB, Downloaded 234 times)
Rich Cini
