Home » RBC Forums » General Discussion » Tiny040 (68040 SBC)
Tiny040 [message #10643] Sat, 30 March 2024 20:05 Go to next message
Tiny040 is an exploratory 3.3V 68040 SBC on 100x100mm pc board. Two events motivated its development; first is the discovery of a batch of 3.3V MC68040RC33V which I previously had thought were SMT parts but are in fact PGA parts; and second is the success of IP940 68040 hosted by IP940base which provides the software base for Tiny040.
Tiny040 will first serve as a test bed to make sure the batch of MC68040RC33V are working parts. The board is sufficiently working right now that I believe at least one chip from that batch of 68040 is good. The second goal of Tiny040 is a software development platform for monitor, diagnostics, utilities and small operating system like EmuTOS and CP/M68K. It is a pathfinder to a full-feature 68040 SBC with 64 meg of memory and video/keyboard capabilities.
One notable feature of Tiny040 is the obvious lack of flash memories. The EPM570 CPLD is located at the solder side of pc board under 68040. It has 1KB of embedded flash on board that's sufficient to bootstrap 68040 and load system files from compact flash. However, the embedded flash is rather tricky to use, so currently I have a 64-byte ROM look-up table using CPLD's logic fabric. This small ROM can load and run program from serial port. This is sufficient to develop application software for Tiny040. Because there are no flash memory, Tiny04 is realized in a 100x100mm 4-layer pc board.
Homepage for Tiny040 is here:https://www.retrobrewcomputers.org/doku.php?id=builderp ages:plasmo:68040:tiny040
/forum/index.php?t=getfile&id=3007&private=0
Re: Tiny040 [message #10671 is a reply to message #10643] Sat, 06 April 2024 13:23 Go to previous messageGo to next message
marcopolo is currently offline  marcopolo
Great job!
My Archives (68K, Old logic, SSB radio): marc.retronik.fr
Re: Tiny040 [message #10753 is a reply to message #10671] Sun, 12 May 2024 08:50 Go to previous messageGo to next message
Hi Bill,
Have you chosen an 3V3 040 in anticipation of upgrading to a 060? Smile
Re: Tiny040 [message #10754 is a reply to message #10753] Sun, 12 May 2024 09:02 Go to previous messageGo to next message
It actually dawned on me just few days ago that 68040 PGA pin assignments are very similar to 68060 PGA. There was an adapter that plug 68060 into 68040 and most of the translation were in 5V to 3.3v. But when I looked closer, I realized 68040 is 18x18 179-pin PGA whereas 68060 is 18x18 223-pin PGA. Had I designed Tiny040 for 68060, it probably can accommodate 3V 68040. I may revise Tiny040 like that because there may be a good supply of 68060 that's fairly inexpensive; that 68060-based Euro card (100x160mm) SBC maybe realistic.
[Updated on: Sun, 12 May 2024 09:03]
Re: Tiny040 [message #10755 is a reply to message #10754] Sun, 12 May 2024 10:02 Go to previous message
I picked up a couple of the QFP 68060s a few years ago to have a go at a board. I liked that they were 3.3V so they'd work with more modern peripherals. But it seems like all of the designs on the net were aimed at turning it into a 68000 for Amigas.
Oh well, someday!
Previous Topic: RomWBW v3.4 Released
Next Topic: New Board Development - SBC6120-RBC Edition
Current Time: Sat Mar 15 07:08:09 PDT 2025
Total time taken to generate the page: 0.00696 seconds
