Home » RBC Forums » General Discussion » new, small footprint 68000
new, small footprint 68000 [message #10243] Tue, 14 February 2023 12:17 Go to next message
Here's a new, small 68k SBC. It has 2MB of SRAM, 128k EEPROM, a 68681 DUART (2 serial ports @ 38,400) and a compact flash interface. The CPU I'm using is an MC68HC000FN20 that runs at 25 MHz. I got a couple of HC Coldfire CPUs (from Germany, I think) that also run at 25 MHz. Everything on the board is either PLCC or through-hole 74LS. The Winbond W27C512 EEPROMS are the only programmable components. It's an excellent little 68k platform that can be easily tinkered with. I've written a little utility to exercise the compact flash, and I can read and write sectors to the CF, and get it to cough up its ID data. Working on a CBIOS to run CP/M68k at the moment.
Please forgive the bodge for the MCP130 watchdog. When I was working on bringing up the board, I was getting spurious resets/halts so I thought that it might be causing them. I removed it, and later found that it was working just fine. At that point, with the other stuff soldered onto the board, I found it very difficult to try to re-mount the thing. So it is patched onto the board. The next version that I build will be much more photogenic!
I'm wondering if it would be possible to run fuzix/mCLinux on it?
Many thanks to Plasmo for his help with some of my bone-headed mistakes, and for offering help with things 68k!
  • Attachment: small68k.jpg
    (Size: 586.84KB, Downloaded 351 times)
Re: new, small footprint 68000 [message #10244 is a reply to message #10243] Tue, 14 February 2023 14:00 Go to previous messageGo to next message
Looks cool! Too little RAM for a contemporary Linux. Fuzix would almost certainly be possible -- do you have a device on board that could be used to generate the timer interrupts? I think you could potentially steal one of the UARTs for this if there's nothing else, but some sort of programmable counter/timer would be ideal.
Re: new, small footprint 68000 [message #10245 is a reply to message #10244] Tue, 14 February 2023 16:11 Go to previous messageGo to next message
I think that the 68681 DUART is capable of a programmable count down that generates an interrupt. I just have to figure out how to set it up.
Re: new, small footprint 68000 [message #10246 is a reply to message #10245] Tue, 14 February 2023 22:49 Go to previous messageGo to next message
greghol is currently offline  greghol
If you can get a bigger FLASH in there then it should be able to boot uClinux.
See Katy68: https://www.bigmessowires.com/68-katy/
Greg
Re: new, small footprint 68000 [message #10247 is a reply to message #10246] Wed, 15 February 2023 07:10 Go to previous messageGo to next message
68681 is just a fancy 68K version of the old 2681 so it's got a timer on it with interrupt. However if you are using that to generate the baud counter you can't also use it for the system timer. Assuming your 68681 is fed off the usual 1.8/3.7/7.3 MHz crystal that should be fine as you've got all the baud rates from the dividers.
Fuzix should run fine on it. Old 2.0 era ucLinux should likewise (and doesn't need a bigger flash as you can RAM load it). Modern uclinux isn't so useful. It's grown a lot as machines have. I sort of got it booting on Tiny68K but it was eating tons of memoy and slow as molasses so i gave up.
If your plumbing and boot is the same as the tiny68k it may actually just run the tiny68k kernel as is. That prods the RAM to check if it's a 2MB T68KRC or a 16MB Tiny68K.
Re: new, small footprint 68000 [message #10783 is a reply to message #10247] Sun, 26 May 2024 14:16 Go to previous messageGo to next message
Here's a new variant of the small 68k described above. This one uses a MC68SEC000FU20 CPU. I find soldering TQFP 0.8mm chips very challenging, but my friend Johan soldered one on an adapter PCB for me. He's a soldering whiz!! I just replaced the PLCC 68000 with four 8x2 headers to accommodate the adapter board. Otherwise, the design is essentially the same. Johan told me that he was able to "free run" that CPU at 50 MHz. I find it will run in this board at 32 MHz, and it is very stable. I tried it at 40 MHz. The monitor will run OK, but it won't boot up CP/M 68k. I think that 40 MHz is right at the limits of the memory and support circuitry. I'd like to try it at 36 MHz, or maybe 38, but I don't have the oscillators to do it. I'll have to order some.
I think it is amazing that a simple through hole, 2 layer PCB can run at those clocks.
  • Attachment: P1011090.JPG
    (Size: 736.72KB, Downloaded 131 times)
Re: new, small footprint 68000 [message #10784 is a reply to message #10783] Sun, 26 May 2024 16:08 Go to previous messageGo to next message
I look up MC68SEC000 and realized it can also run at 3.3V, but Mouser and Digikey are not stocking them. What's your source of MC68SEC000? I'm working on a series of retro computers as mezzanine boards on top of the inexpensive EPM240 development board like this, https://www.ebay.com/itm/354417399620 It is a 3.3V CPLD so the retro computers need to operate at 3.3V as well. I like to include MC68SEC000 in the series.
Re: new, small footprint 68000 [message #10785 is a reply to message #10784] Mon, 27 May 2024 08:46 Go to previous messageGo to next message
Hi Bill -
My friend Johan provided the SEC CPU, so I don't know where he got it, but a quick search on ePay shows a number of sources for the chip at relatively decent prices. Some claim "new", but I wonder if fakes would be an issue?
Re: new, small footprint 68000 [message #10800 is a reply to message #10784] Mon, 24 June 2024 22:30 Go to previous messageGo to next message
floobydust is currently offline  floobydust
Hi Bill,
I picked up some MC68SEC000 processors a couple years ago, eBay seller in Texas. While I was able to get some 20MHz parts, they only show 10MHz parts now. Link:
https://www.ebay.com/itm/202701178842?itmmeta=01J16NYJP48V94 HN06KN6QFD4Y&hash=item2f31ee87da:g:jZQAAOSwLUlc-rsk& itmprp=enc%3AAQAJAAAA4F4NqHdIsoay7Rtos3klVmpkr3C4LCR1EAvWBlY gAVll3IGHZyzlJ7iuaItbPAsyeFdygIEJXbKh3gBW%2B8Vlj1G2n%2ByND4S BAZTROktOHJTuLNHGzpGz%2FiN2NnqXLWHXbn%2Fw7dO0Ktt4UTCqY%2Fze7 bRXDmd13lD%2FrupyN1mm2WJxLHeMZhJGQCkWRICpC3PaIZpwVunnyc6Iy3v aANLrkWDkDeAFy8kesdkBDJ%2F9SKlDOnLuqbc4PA5ibBhuzlmwKLSXzBAF% 2F6vSAPjCVcHljJyv8kA63ucXkrqQV7YFDUR8%7Ctkp%3ABk9SR5ar-tWJZA
I'm also looking to pick up a couple of the EPM240 dev boards. Odd question... if you had a Microdrive (3K8 35-pin IDE 3.3V version), the connector and cable to use it, would you include it as part of the MC68SEC000 Mezzanine board?
Re: new, small footprint 68000 [message #10801 is a reply to message #10800] Tue, 25 June 2024 09:10 Go to previous messageGo to next message
Hi KM,
There's no room on the "mezzanine board", but the 40-pin IDE/CF interface might be able to accommodate it. There's a jumper to power the interface from the PCB (+5v), or not. Leave the jumper off and power your Microdrive separately from a 3.3v source. Not sure if you'd have to do some [or quite a lot?] of level shifting, however.
Re: new, small footprint 68000 [message #10802 is a reply to message #10801] Tue, 25 June 2024 12:47 Go to previous messageGo to next message
By "mezzanine board", floobydust may mean a plug-in board for EPM240 development board. In fact, I've designed such a 68SEC000 mezzanine board for EPM240. It has 68SEC000, 2x 512K RAM, SD card, serial port, and RTC module. It has not been not prototyped, I tried to see how well it fit with the EPM240 dev board. Ideally I want to use SDRAM instead of two 512K SRAM, but it is better to take baby steps. I plan to use the 1KB embedded flash to bootstrap 68K monitor stored in SD card. I don't have microdrive, so I'm more confident with SD card bootstrap or CF disk bootstrap.
/forum/index.php?t=getfile&id=3073&private=0
Re: new, small footprint 68000 [message #10803 is a reply to message #10802] Tue, 25 June 2024 13:46 Go to previous messageGo to next message
Roger, Bill,
I guess I wasn't completely clear... the Microdrive I'm referring to is quite a bit smaller than a Compact Flash card (without the CF socket). The interface is on a 35-pin 0.3mil spacing FPC connector and despite the pinout being 35 pins, it is a full IDE interface. I've been using these for a few years now and very easy to support, as any IDE BIOS or code should work without any modifications.
I'd be happy to send Bill a drive with the FPC cable and the SMT socket to see if he can work it in somehow.
/forum/index.php?t=getfile&id=3074&private=0
I also have the full programming manual which also includes the full electrical and mechanical specifications.
I've also been looking at SMT SRAM, which can be found in 16-bit parallel single package in larger sizes as well, which could reduce the overall physical RAM space quite a bit, but I'm certain you know about these as well.
Re: new, small footprint 68000 [message #10804 is a reply to message #10783] Thu, 27 June 2024 10:45 Go to previous message
jbforrer is currently offline  jbforrer
Greetings,
I built up one of these cool 68SEC00 boards that Roger kindly donated.
The CPU has a 20MHz marking but it free-runs fine at 50MHz.
Experimented with a 50MHz oscillator installed on the board, amazed that it actually runs the monitor code.
That require CPU, DUART, ROM, SRAM and support logic to function properly at that clock rate, basically with DTACK grounded (no wait states).
I've not studied actual timing margins, just been changing clock modules. ROM is 45ns, SRAM 10ns, and the DUART is a Philips SCN68681.
ASM and C (GCC cross compiler) test programs, including memory diagnostics and ASCIIART benchmark loads and execute just fine. The S-record loader runs without flow control.
ASCIIART executes in 6.07s.
Presently, the 82C55 only works for me up to 28.3MHz. So that is what CP/M68K runs at. Not bad either. It would require a small change to add wait states for the 82C55.
Thanks for sharing this project Roger.
Previous Topic: ALTERA MAX7000 adventure to program old CPLD's
Next Topic: ECB enclosure ideas
Current Time: Mon Mar 24 06:13:10 PDT 2025
Total time taken to generate the page: 0.04095 seconds
