Home » RBC Forums » General Discussion » DSKY V3? (new version of DSKY?)
Re: DSKY V3? [message #8476 is a reply to message #8474] Sat, 17 April 2021 15:05 Go to previous messageGo to previous message
danwerner is currently offline  danwerner
It would not be impossible to add in a way for the DSKY to be auto detected. . . . There are two open input pins on the 74LS148(u2) decoder that is used to scan the keyboard matrix. Today they are both tied to low, BUT . . . If we tied them to the LED output from the 74LS138(U1), you could toggle that output and then look for a corresponding input from the row decoder. Seems like a pretty simple change.
I do have the PCBs in and am building up a prototype now. I think for the next run I want to make three changes . . .
#1 I currently had five of the max7219 seven segment modules in stock, and I noticed when building that there are at least three different pinouts of those modules. So I think a jumper block would be appropriate so that almost any of the cheap pre-made modules will work.
#2 Seems like there should be a connector on the new DSKY that is compatible with the old SBC without making a custom cable. The new DSKY only needs 8 bits (4 in/4 out) and the new connector was designed to reflect this, but it might also be good to have the original connector on the board as well. I think a pass through connector would also be useful so that the rest of the ports can be used by other hardware.
#3 Wire up the LED output to the bit 6 and 7 inputs of the decoder to allow hardware detection
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic: Retrocomputer projects using EPM240 development board
Next Topic: Dave Runkle's front panel for the SBC6120-RBC
Current Time: Tue Sep 30 00:46:39 PDT 2025
Total time taken to generate the page: 0.09916 seconds
