Re: Gryphon 68030 [message #827 is a reply to message #823] Thu, 16 June 2016 03:34 Go to previous messageGo to previous message
Sorry, one more thing. If reviewing schematics is not your thing then take a look at the PCB layout and compare the parts against the footprints in the datasheets. I've reviewed it myself but it would be helpful for someone(s) to go through each part and compare the footprints on the PCB to the datasheet. Not just are they the right footprints but are the connected properly, oriented right, pins placed correctly, etc. That's apparently where the last Gryphon prototype PCBs got into trouble so it could potentially save everyone a lot of grief if you find a problem now (early).
Thanks
Andrew Lynch
You can find the dimensioned datasheets for the QFP adapter and 1Mx16 video DRAM below.
http://www.proto-advantage.com/store/datasheets/PA0200_dimen sioned.pdf
http://www.proto-advantage.com/store/datasheets/PA0190_dimen sioned.pdf
http://www.chipworks.com/TOC/Alliance_16m_EDO_CAR-9809-002_T OC.pdf
There is a collection of datasheets on the wiki. Use the link below to access
https://www.retrobrewcomputers.org/doku.php?id=boards:sbc:gr yphon_68030:datasheets
[Updated on: Thu, 16 June 2016 04:25]
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Current Time: Sun Sep 28 20:41:26 PDT 2025
Total time taken to generate the page: 0.50061 seconds
