Re: Gryphon 68030 [message #812 is a reply to message #810] Mon, 13 June 2016 09:39 Go to previous messageGo to previous message
yoda is currently offline  yoda
lynchaj wrote on Mon, 13 June 2016 11:17
I don't mind what video chip foot print we use. However if I need to construct a custom footprint I need detailed technical data.
I think the adapter we have to use is this one for LQFP 14mmX14mm and 0.4mm pitch to PGA-128
http://www.proto-advantage.com/store/product_info.php?produc ts_id=2600014
If it is a straight up PGA-128 it should be an easy swap since that footprint is a JEDEC (?Wink standard part.
However it does not look like a standard PGA-128 to me. I think the MC68030 uses a PGA-128 also but doesn't look like that footprint.
I'll make the swap tonight.
Thanks
Andrew Lynch
Hi Andrew!
My bad. I did not look carefully this morning when I got up - it is the 14mm x 14mm version 0.4mm pitch - I picked the wrong one whey I looked it up. PGA is a misnomer here - it is what they call anything that has pins on all sides here vs DIP when it only has pins on 2 sides. It is 4 dual rows of header pins on 0.1in centers i.e. think of 16 x 2 headers arranged in a square such that the square is 2 inches on a side. I think the image makes it pretty clear - I just need to check at home whether pin 1 is on inside row or outside row.
index.php?t=getfile&id=104&private=0
  • Attachment: PA0190_2.jpg
    (Size: 33.94KB, Downloaded 2452 times)
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Current Time: Fri Sep 26 22:42:53 PDT 2025
Total time taken to generate the page: 0.00972 seconds
