Re: Gryphon 68030 [message #807 is a reply to message #789] Mon, 13 June 2016 04:58 Go to previous messageGo to previous message
yoda wrote on Sun, 12 June 2016 10:26
Hi Andrew
I have downloaded the schematics and will start to take a look at them - probably will take a week or so. I need to compare to all my errata notes as well that did not make 1.1 of schematics. Quick perusal I can say there are changes in the IDE area as the '139 area needs updated and the connector on video should be a VGA connector instead of a DB15 connector. Also I think most would prefer the Serial I/O come out on the board to headers that a TTL to USB adapter would accept. For the cost of the Max 232, caps and db9 the dongles tend to be cheaper and work better with modern PCs.
OK. I can roll in the changes for the IDE no problem. The VGA connector is an HD-15 on the PCB although the schematic indicates a DB15. The pin connections are identical other than the arrangement so it shouldn't be a problem. Adding serial headers (5 pin SIL, if I recall correctly) is no problem. Just leave the caps, MAX232, and serial ports unpopulated if you prefer those serial header to USB cables. Laying out the PCB gave me a lot of insight and resulted in numerous corrections to the schematic and part footprint selections.
Andrew Lynch
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Current Time: Sat Sep 27 00:15:53 PDT 2025
Total time taken to generate the page: 0.01241 seconds
