Home » RBC Forums » General Discussion » CB030, A 68030 SBC for hobbyists
Re: CB030, A 68030 SBC for hobbyists [message #7855 is a reply to message #6931] Wed, 08 July 2020 11:52 Go to previous messageGo to previous message
Yves-D. is currently offline  Yves-D.
/forum/index.php?t=getfile&id=1815&private=0
@Plasmo
Just to let you know: another CB030 is alive, currently running the 16MB RAM test-routines.
I'm enjoying EhBasic for the moment Laughing , the CF-adapter is on order for putting the Linux port on it.
I've slightly overclocked the CPU with the 24.57MHz oscillator I had on hand.
I didn't check but remember reading that the RAM-refresh cycle is already tight with 60nS Rams at 24MHz. But it's stable so far in the RAM check.
I had a hard time getting some output from the serial port as I didn't notice the RTS/CTS pins from the USB-TTL-adapter being soldered to point T4 / T11.
It's visible your pictures, if you know where to look. Very Happy
You could add a note for people using other USB-TTL-adapters that T11 must be connected to CTS and T4 to RTS.
On the logic analyser I saw the 68681 chip-select being busy and the chip responded with DTACK, i was pretty confident that the cb030 was up and running.
Just something with the output being wrong.
The Aha-moment came after reanalysing the annotated pictures and hardware handshake being mentioned in the BIOS notes. I only had GND,RX,TX connected - so that had to be it.
Thanks for your nice work being offered to the community
PS: the cb030 is sitting near my 68SEC000-Altoirola in Altoids tin-can-format, don't ask - someone had to do it Rolling Eyes , for footprint comparison
It's a 5V 12MHz 512kb Flash / 128k RAM board, using CMOS 68C681 and low power GAL - yielding around 50mA total current consumption. The GAL being responsible for 40mA alone.
It's quite amazing what they did at the end of the 68000 life-cycle.
I'll also try to construct a 3.3V variant of the same board: the 68SEC000 is 3.3V capable, I've got 3.3V RAM, Flash and GAL.
Then there's a specific Philips DUART (SC28L92) being 3.3/5V capable, 99% pin compatible (not 100%) and 99% software compatible - some changes are necessary
Kind regards,
Yves
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic: ZRC, A Z80 SBC for ROMWBW
Next Topic: Neat '040 boot ROM setup
Current Time: Sat Sep 27 11:08:30 PDT 2025
Total time taken to generate the page: 0.29714 seconds
