Home » RBC Forums » General Discussion » CB030, A 68030 SBC for hobbyists
Re: CB030, A 68030 SBC for hobbyists [message #7408 is a reply to message #7402] Thu, 02 April 2020 19:21 Go to previous messageGo to previous message
Mike,
Wow! Most excellent!!
However, since I'm not a Linux user, I'll need more help...
My setup is CB030 with 64 meg DRAM, I have the new100Hz interrupt CPLD. My CF disk is a 2G Verbatim. I burn a EPROM with EPROM binary from CB030bios-64.bin.zip. It boots and here is the dialog:
T030 ROM BIOS v2.11 (c) 2018 Tobias Rathje
CB030 version ported by Mike McDonald 2020
RAM (hard coded): 64MB
Build: Mar 30 2020 10:09:47
?  - Help
a  - Load and execute EhBasic
b  - Toggle heartbeat LED: b <val>
c  - Modify cache register: c <val>
C  - Checksum RAM: C <addr>
d  - Dump address: d <addr>
e  - Force exception: e <num>
h  - Perform hardisk command - h? for help
i  - Set interrupt level: i <level>
g  - Run: g <addr>
l  - Load linux: l <cmdline> <ramdisk start addr> <ramdisk size>
m  - Mandelbrot test: m <count>
q  - Perform RAM check: q <mode> <address> <size> <count>
r  - Dump registers
v  - Load and execute Test BIOS from SD card
u  - Run in user mode: u <addr>
w  - Write single byte: w <addr> <data>
x  - Transfer file with XMODEM: x <addr>
z  - Soft reset
<#> - Run script "#"
#> hl
Volume label:
   0 File(s),         0 bytes total
   0 Dir(s),    1949472KiB free
So it can read the CF disk. Now I assume the disk needs to be formatted as FAT partition and files 0.cmd, initrd.gz, and linux.bin copied into the partition? Do I need to do that with a Linux system? What command I should issue at the #> prompt to boot up Linux?
PS, In case I haven't said "Wow!", here it is: WOW!!!
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic: ZRC, A Z80 SBC for ROMWBW
Next Topic: Neat '040 boot ROM setup
Current Time: Sat Sep 27 12:11:18 PDT 2025
Total time taken to generate the page: 0.13253 seconds
