Home » RBC Forums » General Discussion » CB030, A 68030 SBC for hobbyists
Re: CB030, A 68030 SBC for hobbyists [message #7154 is a reply to message #7152] Mon, 02 March 2020 21:53 Go to previous messageGo to previous message
mikemac is currently offline  mikemac
plasmo wrote on Mon, 02 March 2020 21:58
Mike,
You'll find the following files on drive A: which is a read-only drive reside on the EPROM, so they are always there even without a CF disk
A>dir
A: ME       68K : GKERMIT  68K : AS68SYMB DAT : DDT68000 68K : DDT      68K
A: PIP      68K : INIT     68K : STAT     68K : AS68     68K : LINK68   68K
A: DUMP     68K : LO68     68K : ED       68K : AR68     68K : MORE     68K
A: FIND     68K
A>
The three particularly useful files are PIP, INIT, and GKERMIT. When you insert a new CF disk, you first initialize it with "init b:", "init c:", init d:", and "init e:" to clear out the directories of four 8-meg disks on CF. Then you can do "pip b:=a:*.*[v]" to see if files can be copied correctly from ROM drive to CF drive. If that's successful, then you can use GKERMIT to transfer files from your PC to CF drives.
To use GKERMIT to transfer files from you existing CF disk to PC, type:
a:gkermit -s filename <- the filename can be wildcard, so it can be *.* to transfer the entire disk to PC
on terminal emulator, look for the kermit transfer protocol and enable file receive. For TeraTerm it is File->Transfer->Kermit->Receive
To transfer files from PC to CB030, type:
a:gkermit -r
on the terminal emulator, look for the kermit transfer protocol and select file send. For TeraTerm it is
File->Transfer->Kermit->Send then select the file(s) to send.
OK, thanks. I've used kermit on other non CPM systems before so I'm familiar with the concept. 'pip' is a new one for me. Sounds like a disk to disk copy command.
Copying B: to the PC and then back to a new B: using gkermit sounds like an overnight job. : Shocked
Is copying A: to a new B: enough to verify the CF to be working? IE the CF that don't work would be detected by such an exercise?
Mike
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic: ZRC, A Z80 SBC for ROMWBW
Next Topic: Neat '040 boot ROM setup
Current Time: Sat Sep 27 06:11:28 PDT 2025
Total time taken to generate the page: 0.29501 seconds
