Home » RBC Forums » General Discussion » Question ISA BUS clock
Re: Question ISA BUS clock [message #6200 is a reply to message #6198] Mon, 01 April 2019 12:01 Go to previous messageGo to previous message
Sergey is currently offline  Sergey
It would help to describe what are you trying to debug Smile
B30/OSC - 14.31818 MHz clock. In the original IBM PC, IBM XT, and clones of thereof this is the OSC output of 8284 clock generator.
B20/CLK - Buffered CPU clock, it is slightly delayed from the actual CPU CLK signal because of the buffer. In the original IBM PC/XT and the clones it is 4.77 MHz (exactly one third of OSC and aligned to it). In various "turbo XT" systems and early ATs this signal reflected the CPU clock frequency. In later/faster ATs (probably anything faster than 8 MHz), it is an ISA bus clock, that might not be correlated to the CPU clock.
AEN - Indicates a DMA bus cycle, used by I/O devices to prevent from being selected during the DMA cycles.
ALE - In 8088/8086/80188/80186/80286 it is activated during the second half of T1 bus cycle, while the CPU outputs the address. It is used by address latches to latch the address. It is not particularly useful (and even harmful) in PC/XT/8-bit ISA bus systems /cards. In AT/16-bit ISA variant higher address lines (LA17-LA23) are unlatched, and this signal can be used by the ISA controllers to determine when the address is stable and latch or decode it.
In your diagram above wide ALE pulses are rather weird. I'd expect to see only the short ones.
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic: A simple CP/M Z80 SBC without glue logic
Next Topic: KISS68030 GALs
Current Time: Mon Sep 29 05:25:03 PDT 2025
Total time taken to generate the page: 0.00655 seconds
