Home » RBC Forums » General Discussion » A simple CP/M Z80 SBC without glue logic
Re: A simple CP/M Z80 SBC without glue logic [message #6130 is a reply to message #6126] Thu, 14 March 2019 10:50 Go to previous messageGo to previous message
wsm is currently offline  wsm
Interesting idea. This is similar to what I did when I started my Z180 MinZ design ... minimal components. I think there might be a COUPLE of additional chips required. Firstly, I like to always add a reset supervisor / voltage monitor which also allows a reset pushbutton. I admit to software development goofs that require resets Smile
Serial I/O can be handled on a header for external USB or RS-232 adapters. I chose to make two variants of my board, one with a CP2015 USB bridge and one that allows either an RS-232 translator or a TTL header.
At first glance it appears the KIO CS* can be tied low since it also uses IORQ* and is the only I/O device. However, I think that may get into some issues with interrupt responses (M1* plus IORQ*) which would be both a vector read AND an I/O write.
The other question I would have is on the ROM / RAM chip selects. There is a need to differentiate both memory cycles (MREQ*) and RAM vs. ROM. I know there are some memories with dual selects (can't remember exact ones offhand) but many [most?] of the newer ones only have a single select and expect an external decoder.
Perhaps weak pull-up vs. pull-down on a KIO port can differentiate ROM vs. RAM on reset and until the KIO can be programmed. That still leaves the issue of differentiating I/O versus memory cycles.
Just my $.02 while I wait for another cup of coffee to kick in. I'm thinking that you will require a decoder i.e. glue.
While you're toying with ideas, why not also look at the Z84C15 which has basically the same features of the Z80+KIO but integrates the CPU and also has memory selects. The downside is that it's a VQFP-100 package.
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic: SDC_68k
Next Topic: Question ISA BUS clock
Current Time: Sun Sep 28 02:41:37 PDT 2025
Total time taken to generate the page: 0.00684 seconds
