Home » RBC Forums » General Discussion » SBC VER 2 First Build with K13 next to ECB Connector (Trying to bring up board for the 1st time.)
Re: SBC VER 2 First Build with K13 next to ECB Connector [message #2478 is a reply to message #2476] Wed, 19 April 2017 23:37 Go to previous message
jcoffman is currently offline  jcoffman
index.php?t=getfile&id=370&private=0
UNA 2.1 is the latest release. Good there. "s" is the "small" 512K ROM image.
Most disturbing: LED D1 not lit. U17 (244), U7 (14), & U5 (125) must all be installed. Plus, with U17 missing, the board may be inoperable. U17 drives /WAIT and /BUSRQ, which are direct Z80 inputs. I don't know what happens if they are left floating. They need to be tied HIGH. U17 insures this.
Okay to omit U8,U9,U11. Probably okay to omit U10. With no external peripherals, & no ECB bus, K13 may be left open for the time being.
RE: jumpers pin 1 is ALWAYS the square pin. To be sure, turn the board over and check from the bottom. I think your assumptions above are incorrect. I see a lot of pin1's toward the Z80.
Note I don't use the DS1210, so it is necessary to short pins 1-8 and 5-6 in the socket.
  • Attachment: IMG_0860.JPG
    (Size: 147.93KB, Downloaded 582 times)
Read Message
Read Message
Read Message
Previous Topic: UIDE
Next Topic: Gryphon 68030
Current Time: Mon Sep 29 16:16:25 PDT 2025
Total time taken to generate the page: 0.00842 seconds
