Re: Gryphon 68030 [message #2331 is a reply to message #2298] Sun, 09 April 2017 20:22 Go to previous messageGo to previous message
rhkoolstar wrote on Sat, 08 April 2017 11:30
I'm using the following:
$ md5sum freeroute.jar
212b8886718d0a7b62b57c51362cdcf7  freeroute.jar
$ java -version
openjdk version "1.8.0_121"
OpenJDK Runtime Environment (build 1.8.0_121-b13)
OpenJDK 64-Bit Server VM (build 25.121-b13, mixed mode)
and I never had any crashes.
I'm running on a somewhat beefy headless server (i5-4690 CPU @ 3.50GHz, 8GB RAM) with ssh -X, which incidentally also runs a minecraft server at the same time
I always let Freeroute run until completion in one go (no saves or interrupts) which generally takes 40-50 optimize passes.
I'm not building really big (max euro card 100x160mm) but the boards are complicated enough (My project under development is currently 384 nodes, 86 nets on 100x80 with a mix of through-hole and SMD. routing takes about 2.5 hours.
Rienk
I'm surprised to learn how long it takes the freeRouter to route. I'm using a 20-year old pc board tool, WinDraft from IVEX which is out of business for at least a dozen year. It is a low-budget, mediocre tool that can only run on Windows ME, but it was bundled with a permanent license and interface to the Specctra router (originally Cooper & Chyan router), which is also a 20-year old version (version 8). My pcb tool is a Dell laptop with Pentium III and 512MB of memory. I just run a test of the router using Tiny302 which is 100mm x 100mm pcb, 8 mil traces, 8 mil clearance, 25 mil power/ground traces, 132 nets and 406 nodes. The board is packed with components, it has components at backside and a 20-pin 300-mil component under a 600-mil component. It completes the routes 100% in 6 minutes and 11 seconds. All the routes have right angle corners and I don't know what route optimizer does, but the board works fine.
Because of the Windows ME limitation, I'm looking for a better pcb package, but I'm reluctant to use KiCad, at least not with the freeRouter interface. I wonder if KiCad works with Specctra router?
[Updated on: Sun, 09 April 2017 20:22]
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Current Time: Fri Sep 26 19:15:33 PDT 2025
Total time taken to generate the page: 0.28977 seconds
