Home » RBC Forums » General Discussion » CB030, A 68030 SBC for hobbyists
Re: CB030, A 68030 SBC for hobbyists [message #10530 is a reply to message #10375] |
Tue, 05 December 2023 15:09  |
mikesmith
Messages: 80 Registered: March 2018
Member |
Apologies @coolbear, work and other hobbies took over and I haven't had time to keep in touch. Some of that pressure is off, so hopefully I can spend a little more time tinkering with retro stuff again.
I'm sorry I don't have much in the way of suggestions for getting the tools running on anything other than macOS; I will take a stab at getting a Windows system up and see if I can come up with a recipe, but someone more familiar with the platform is likely to be more useful there. In theory modern Windows should still run older stuff, as long as you can find / install the required runtime libraries.
To some of the other questions:
Quote:
I am setting up the OS9 68K SDK v12 compile package. I have unzipped os9_68k_sdk_v12.zip and put the contents in "M:\MWOS".
Do I put the contents of os9-m68k-ports-main.zip in M:\MWOS as well?
You can check out the ports repo more or less anywhere, but make sure that there are no spaces in any of the parent directory names. Using the zip archives is less than ideal, as it makes it very hard for you to keep track of your own changes at the same time as taking in new changes that might happen upstream.
Quote:
I want to copy the CB030 folder to Tiny68K folder and try to port it, of course, to the Tiny68K, MB012 and T68KRC boards. Anything special I need to know about making these changes. I have never done this before so please include every little detail if possible.
That would be essentially the same as doing the work from scratch... but off the top of my head, you would want to at least:
- adjust ROM_CBOOT/sysinit.a to perform the correct (possibly minimal) early startup tasks
- adjust the bootfile lists to select the correct kernel and other system modules
- adjust systype.d to select the correct CPU type, I/O addresses, vectors, CFIDE configuration, etc.
- write a new ticker driver to use the 68681 timer and sort out any conflicts with the (nigh-unreadable) OS-9 68681 serial driver
- adjust the RTC driver as required; either to stub it out so that the system will prompt for the time / date at bootup, or to read the time/date from some other RTC of your choosing (IIRC there are issues with Bill's board layout that make the tiny68k onboard RTC non-functional, you could use the RTC he designed for CB030).
- adjust the bootfiles and probably other Makefiles so that only the bootloader goes in the serial ROM
- add new disk image generation logic / config as required to build a bootable CF image
There's probably more; I am still paging all of this back in. I have a sneaking suspicion that I convinced myself that using the '681 timer for the ticker was going to cause problems, but I don't see it in my notes and it's not immediately obvious what it would be, so it might? work.
Quote:
Would one of the "Frugal RAM/ROM 512K" or the "Improved 512K RAM/ROM" RC boards and my MB012 board with 2 RC slots be enough to boot OS9 68K from the flash memory and be up and running to access the OS9 filesystem on the CF Card?
I would expect that a basic MB012 would be plenty to run OS-9, without needing any additional memory boards. It'd need a little tinkering to get there from a tiny68k port, and it would have the same basic set of prerequisites.
Quote:
Does the OS9 port require any hardware mods - notably the 16-bit CF mods?
What about the timer?
You need the 100Hz tick version of the CPLD. It's best to have one of Bill's realtime clock modules, since OS-9 likes to know the time / date at boot.
The CB030 port configures the CF driver in 8-bit mode. I don't know if this would conflict with the 16bit mod, I don't think I ever looked to see.
Hopefully this helps a little. I will probably have more to share in a bit when I have refreshed everything and got myself up and going again.
[Updated on: Tue, 05 December 2023 22:12] Report message to a moderator
By: plasmo on Sat, 18 January 2020 09:44
By: rwiker on Sun, 19 January 2020 00:27
By: plasmo on Sun, 19 January 2020 04:35
By: plasmo on Sun, 19 January 2020 06:05
By: jcoffman on Mon, 20 January 2020 10:24
By: plasmo on Mon, 20 January 2020 20:39
By: jcoffman on Tue, 21 January 2020 12:47
By: plasmo on Thu, 23 January 2020 20:17
By: rwiker on Fri, 24 January 2020 00:23
By: tobster on Fri, 24 January 2020 00:25
By: plasmo on Fri, 24 January 2020 07:05
By: lowen on Fri, 24 January 2020 19:21
By: plasmo on Fri, 24 January 2020 21:15
By: rwiker on Sat, 25 January 2020 01:07
By: UhClem on Fri, 07 February 2020 17:19
By: plasmo on Thu, 06 February 2020 19:14
By: plasmo on Fri, 07 February 2020 10:22
By: plasmo on Sat, 08 February 2020 06:36
By: plasmo on Thu, 27 February 2020 20:29
By: rwiker on Sat, 29 February 2020 08:31
By: plasmo on Sat, 29 February 2020 19:02
By: mikemac on Mon, 02 March 2020 16:57
By: plasmo on Mon, 02 March 2020 17:51
By: plasmo on Mon, 02 March 2020 19:24
By: mikemac on Mon, 02 March 2020 20:33
By: mikemac on Mon, 02 March 2020 21:44
By: plasmo on Mon, 02 March 2020 20:58
By: mikemac on Mon, 02 March 2020 21:53
By: plasmo on Tue, 03 March 2020 07:17
By: mikemac on Tue, 03 March 2020 07:28
By: plasmo on Tue, 03 March 2020 07:52
By: mikemac on Tue, 03 March 2020 08:56
By: mikemac on Wed, 04 March 2020 19:05
By: plasmo on Wed, 04 March 2020 19:30
By: mikemac on Thu, 05 March 2020 08:39
By: mikemac on Thu, 05 March 2020 13:57
By: plasmo on Thu, 05 March 2020 20:20
By: mikemac on Thu, 05 March 2020 17:59
By: plasmo on Thu, 05 March 2020 20:35
By: plasmo on Thu, 05 March 2020 21:19
By: mikemac on Thu, 05 March 2020 23:07
By: mikemac on Fri, 06 March 2020 15:34
By: plasmo on Fri, 06 March 2020 15:49
By: mikemac on Fri, 06 March 2020 15:56
By: mikemac on Fri, 06 March 2020 16:02
By: plasmo on Fri, 06 March 2020 16:31
By: mikemac on Fri, 06 March 2020 16:34
By: plasmo on Fri, 06 March 2020 17:09
By: mikemac on Fri, 06 March 2020 19:18
By: plasmo on Fri, 06 March 2020 20:06
By: mikemac on Fri, 13 March 2020 14:43
By: plasmo on Fri, 13 March 2020 18:05
By: mikemac on Sat, 14 March 2020 15:39
By: plasmo on Sun, 15 March 2020 07:39
By: mikemac on Sun, 15 March 2020 10:07
By: mikemac on Thu, 05 March 2020 08:44
By: mikemac on Sun, 15 March 2020 10:12
By: plasmo on Sun, 15 March 2020 11:37
By: mikemac on Sun, 15 March 2020 16:13
By: plasmo on Sun, 15 March 2020 19:35
By: mikemac on Sun, 15 March 2020 21:31
By: plasmo on Mon, 16 March 2020 06:59
By: mikemac on Mon, 16 March 2020 08:57
By: mikemac on Mon, 16 March 2020 21:29
By: plasmo on Tue, 17 March 2020 06:29
By: mikemac on Tue, 17 March 2020 07:51
By: plasmo on Tue, 17 March 2020 08:28
By: mikemac on Tue, 17 March 2020 09:18
By: plasmo on Tue, 17 March 2020 09:55
By: mikemac on Tue, 17 March 2020 10:44
By: mikemac on Tue, 17 March 2020 15:13
By: mikemac on Tue, 17 March 2020 15:53
By: plasmo on Tue, 17 March 2020 18:28
By: mikemac on Fri, 27 March 2020 11:57
By: tingo on Fri, 27 March 2020 15:45
By: mikemac on Sat, 28 March 2020 09:35
By: mikemac on Sat, 28 March 2020 17:16
By: mikemac on Sat, 28 March 2020 18:32
By: plasmo on Sat, 28 March 2020 18:35
By: mikemac on Sat, 28 March 2020 19:15
By: plasmo on Sat, 28 March 2020 19:26
By: mikemac on Sat, 28 March 2020 20:29
By: plasmo on Sat, 28 March 2020 20:47
By: mikemac on Sat, 28 March 2020 21:43
By: mikemac on Thu, 02 April 2020 09:00
By: plasmo on Thu, 02 April 2020 19:21
By: plasmo on Thu, 02 April 2020 19:35
By: plasmo on Thu, 02 April 2020 19:40
By: mikemac on Thu, 02 April 2020 19:41
By: plasmo on Thu, 02 April 2020 20:13
By: plasmo on Wed, 08 April 2020 11:34
By: mikemac on Wed, 08 April 2020 12:02
By: plasmo on Wed, 08 April 2020 16:31
By: plasmo on Wed, 08 April 2020 16:47
By: plasmo on Wed, 08 April 2020 16:22
By: plasmo on Thu, 09 April 2020 20:08
By: mikemac on Thu, 09 April 2020 20:58
By: mikemac on Thu, 09 April 2020 21:06
By: plasmo on Fri, 10 April 2020 06:51
By: plasmo on Fri, 10 April 2020 07:54
By: plasmo on Sat, 11 April 2020 06:55
By: plasmo on Sun, 12 April 2020 04:28
By: mikemac on Fri, 17 April 2020 21:47
By: plasmo on Tue, 16 June 2020 20:08
By: plasmo on Wed, 17 June 2020 17:47
By: plasmo on Thu, 18 June 2020 17:35
By: plasmo on Sun, 21 June 2020 19:47
By: plasmo on Wed, 24 June 2020 17:31
By: mikemac on Wed, 24 June 2020 22:37
By: mikemac on Wed, 01 July 2020 08:27
By: plasmo on Thu, 09 April 2020 20:17
By: plasmo on Thu, 02 July 2020 04:26
By: plasmo on Sun, 05 July 2020 04:20
By: plasmo on Sun, 12 July 2020 13:17
By: plasmo on Tue, 14 July 2020 18:07
By: mikemac on Wed, 15 July 2020 14:51
By: mikemac on Thu, 16 July 2020 18:03
By: Yves-D. on Wed, 08 July 2020 11:52
By: Yves-D. on Wed, 08 July 2020 11:58
By: plasmo on Thu, 09 July 2020 05:07
By: Yves-D. on Mon, 10 August 2020 04:29
By: mikemac on Mon, 10 August 2020 12:29
By: plasmo on Wed, 12 January 2022 21:12
By: plasmo on Fri, 28 January 2022 07:40
By: plasmo on Mon, 01 August 2022 03:14
By: e2k on Mon, 01 August 2022 10:58
By: plasmo on Sat, 27 August 2022 18:47
By: plasmo on Mon, 29 August 2022 19:19
By: plasmo on Mon, 12 September 2022 13:59
By: mikesmith on Tue, 13 September 2022 11:31
By: mikesmith on Tue, 13 September 2022 16:54
By: plasmo on Tue, 14 March 2023 13:30
By: plasmo on Wed, 15 March 2023 06:45
By: plasmo on Wed, 15 March 2023 17:23
By: plasmo on Thu, 30 March 2023 17:58
By: plasmo on Fri, 12 August 2022 09:33
By: plasmo on Sun, 14 August 2022 19:11
By: plasmo on Mon, 15 August 2022 19:29
By: plasmo on Tue, 16 August 2022 13:18
By: Yves-D. on Thu, 18 August 2022 23:26
By: plasmo on Sun, 21 August 2022 05:37
By: plasmo on Mon, 22 August 2022 16:24
By: e2k on Mon, 22 August 2022 23:33
By: e2k on Wed, 24 August 2022 22:53
By: plasmo on Tue, 02 August 2022 04:21
By: plasmo on Tue, 02 August 2022 14:51
By: plasmo on Wed, 03 August 2022 11:59
By: plasmo on Thu, 04 August 2022 18:37
By: plasmo on Fri, 05 August 2022 16:47
By: plasmo on Sat, 06 August 2022 17:16
By: plasmo on Mon, 08 August 2022 18:18
By: simonj5 on Wed, 10 August 2022 01:38
By: plasmo on Wed, 10 August 2022 15:20
By: plasmo on Fri, 12 August 2022 09:39
By: plasmo on Tue, 20 June 2023 11:42
Current Time: Sun Sep 28 23:55:49 PDT 2025
Total time taken to generate the page: 0.40110 seconds
