Home » RBC Forums » General Discussion » CB030, A 68030 SBC for hobbyists
Re: CB030, A 68030 SBC for hobbyists [message #10096 is a reply to message #10095] |
Mon, 15 August 2022 21:01   |
mikesmith
Messages: 80 Registered: March 2018
Member |
Which utilities did you try? OS-9 disk stuff is a bit... interesting. More reading may make things clearer, but basically for the CF disk there are two parts; the driver module (cfide) and the descriptor modules (c0, c0_fmt and dd) that configure it.
For a simple test, insert a CF card and type 'dump /c0@'. That should give you a raw hexdump of the contents of the card, starting at block 0. 'c0' is the descriptor name, '/' means to look for a device rather than a file, and '@' means to open it raw rather than to try to mount the filesystem. You can think of '/c0' as a drive specifier like 'A:'.
'dd' is just 'c0' but with the "default" disk name (dd = default disk). c0_fmt is c0 but it allows writing to LBA0, which is required to format the disk or install a bootfile.
Here's a transcript of me formatting a CF card and installing a bootfile on it, with contents from the ROM bootfile. This depends on the 'save' and 'build' commands being in the ROM bootfile that you start with - you can add these by editing ports/CB030/BOOTFILE/dev.bl. I'll add them to the github repo shortly and add a version of this to the README.
$ format c0_fmt
... blah blah ...
Formatting device: c0_fmt
proceed? y
this is a HARD disk - are you sure? y
physical format desired? n
physical verify desired? n
volume name: boot
building media bitmap...
... blah blah ...
writing root directory structure
$ chd /c0_fmt
CompactFlash driver build 39
$ save -f=OS9Boot kernel ioman init syscache ssm fpu tkcb030 rtclock scf null nil pipeman pipe sc68681 term t1 rbf cfide dd sysgo mshell csl pd
$ os9gen -e /c0_fmt -q=OS9Boot
$ makdir SYS
$ chd SYS
$ build startup
? chd /dd
? chx /dd/CMDS
<<< board reset >>>
OS-9/68K System Bootstrap
Now trying to boot from CompactFlash.
A valid OS-9 bootfile was found.
pd: can't open current directory. $ mdir -e
Addr Size Owner Perm Type Revs Ed # Lnk Module name
00007100 28476 0.0 0555 Sys a000 375 2 kernel
0000e03c 5660 0.0 0555 Sys a000 37 1 ioman
0000f658 330 0.0 0555 Sys 8000 51 1 init
0000f7a2 406 0.0 0555 Sys a000 25 1 syscache
0000f938 1908 0.0 0555 Sys a000 41 1 ssm
000100ac 12848 0.0 0555 Sys a000 18 1 fpu
000132dc 276 0.0 0555 Sys a000 11 1 tkcb030
... etc. but see these low addresses - these modules are in RAM where the bootfile was loaded from CF
00038920 4312 1.0 0555 Prog c001 30 0 pd
fe026986 148 0.0 0555 Desc 8000 26 1 c0
fe026a1a 152 0.0 0555 Desc 8000 26 0 c0_fmt
fe0471dc 4838 1.0 0555 Prog c001 39 0 attr
fe0484c2 2756 0.0 0555 Prog c001 10 0 break
fe048f86 2670 1.0 0555 Prog c001 24 0 build
... see how these have been discovered from the bootfile that's in ROM, because the bootloader told the kernel to look there as well. They will run just fine out of the ROM (slowly, of course).
fe0721e6 13838 1.0 0555 Data 8001 1 0 basic68k.stb
... still debugging this one
You can use 'save' to copy program modules from the ROM into /dd/CMDS and then flash NOBUG/romimage.diskboot. When you boot, it will run /SYS/startup which in the example above will change your data directory (chd) to /dd and your execution directory (chx) to /dd/CMDS. At that point, any commands you type will run off the CF rather than from the in-memory sticky copies (the diskboot ROM does have a few emergency commands in it).
[Updated on: Mon, 15 August 2022 21:08] Report message to a moderator
By: plasmo on Sat, 18 January 2020 09:44
By: rwiker on Sun, 19 January 2020 00:27
By: plasmo on Sun, 19 January 2020 04:35
By: plasmo on Sun, 19 January 2020 06:05
By: jcoffman on Mon, 20 January 2020 10:24
By: plasmo on Mon, 20 January 2020 20:39
By: jcoffman on Tue, 21 January 2020 12:47
By: plasmo on Thu, 23 January 2020 20:17
By: rwiker on Fri, 24 January 2020 00:23
By: tobster on Fri, 24 January 2020 00:25
By: plasmo on Fri, 24 January 2020 07:05
By: lowen on Fri, 24 January 2020 19:21
By: plasmo on Fri, 24 January 2020 21:15
By: rwiker on Sat, 25 January 2020 01:07
By: UhClem on Fri, 07 February 2020 17:19
By: plasmo on Thu, 06 February 2020 19:14
By: plasmo on Fri, 07 February 2020 10:22
By: plasmo on Sat, 08 February 2020 06:36
By: plasmo on Thu, 27 February 2020 20:29
By: rwiker on Sat, 29 February 2020 08:31
By: plasmo on Sat, 29 February 2020 19:02
By: mikemac on Mon, 02 March 2020 16:57
By: plasmo on Mon, 02 March 2020 17:51
By: plasmo on Mon, 02 March 2020 19:24
By: mikemac on Mon, 02 March 2020 20:33
By: mikemac on Mon, 02 March 2020 21:44
By: plasmo on Mon, 02 March 2020 20:58
By: mikemac on Mon, 02 March 2020 21:53
By: plasmo on Tue, 03 March 2020 07:17
By: mikemac on Tue, 03 March 2020 07:28
By: plasmo on Tue, 03 March 2020 07:52
By: mikemac on Tue, 03 March 2020 08:56
By: mikemac on Wed, 04 March 2020 19:05
By: plasmo on Wed, 04 March 2020 19:30
By: mikemac on Thu, 05 March 2020 08:39
By: mikemac on Thu, 05 March 2020 13:57
By: plasmo on Thu, 05 March 2020 20:20
By: mikemac on Thu, 05 March 2020 17:59
By: plasmo on Thu, 05 March 2020 20:35
By: plasmo on Thu, 05 March 2020 21:19
By: mikemac on Thu, 05 March 2020 23:07
By: mikemac on Fri, 06 March 2020 15:34
By: plasmo on Fri, 06 March 2020 15:49
By: mikemac on Fri, 06 March 2020 15:56
By: mikemac on Fri, 06 March 2020 16:02
By: plasmo on Fri, 06 March 2020 16:31
By: mikemac on Fri, 06 March 2020 16:34
By: plasmo on Fri, 06 March 2020 17:09
By: mikemac on Fri, 06 March 2020 19:18
By: plasmo on Fri, 06 March 2020 20:06
By: mikemac on Fri, 13 March 2020 14:43
By: plasmo on Fri, 13 March 2020 18:05
By: mikemac on Sat, 14 March 2020 15:39
By: plasmo on Sun, 15 March 2020 07:39
By: mikemac on Sun, 15 March 2020 10:07
By: mikemac on Thu, 05 March 2020 08:44
By: mikemac on Sun, 15 March 2020 10:12
By: plasmo on Sun, 15 March 2020 11:37
By: mikemac on Sun, 15 March 2020 16:13
By: plasmo on Sun, 15 March 2020 19:35
By: mikemac on Sun, 15 March 2020 21:31
By: plasmo on Mon, 16 March 2020 06:59
By: mikemac on Mon, 16 March 2020 08:57
By: mikemac on Mon, 16 March 2020 21:29
By: plasmo on Tue, 17 March 2020 06:29
By: mikemac on Tue, 17 March 2020 07:51
By: plasmo on Tue, 17 March 2020 08:28
By: mikemac on Tue, 17 March 2020 09:18
By: plasmo on Tue, 17 March 2020 09:55
By: mikemac on Tue, 17 March 2020 10:44
By: mikemac on Tue, 17 March 2020 15:13
By: mikemac on Tue, 17 March 2020 15:53
By: plasmo on Tue, 17 March 2020 18:28
By: mikemac on Fri, 27 March 2020 11:57
By: tingo on Fri, 27 March 2020 15:45
By: mikemac on Sat, 28 March 2020 09:35
By: mikemac on Sat, 28 March 2020 17:16
By: mikemac on Sat, 28 March 2020 18:32
By: plasmo on Sat, 28 March 2020 18:35
By: mikemac on Sat, 28 March 2020 19:15
By: plasmo on Sat, 28 March 2020 19:26
By: mikemac on Sat, 28 March 2020 20:29
By: plasmo on Sat, 28 March 2020 20:47
By: mikemac on Sat, 28 March 2020 21:43
By: mikemac on Thu, 02 April 2020 09:00
By: plasmo on Thu, 02 April 2020 19:21
By: plasmo on Thu, 02 April 2020 19:35
By: plasmo on Thu, 02 April 2020 19:40
By: mikemac on Thu, 02 April 2020 19:41
By: plasmo on Thu, 02 April 2020 20:13
By: plasmo on Wed, 08 April 2020 11:34
By: mikemac on Wed, 08 April 2020 12:02
By: plasmo on Wed, 08 April 2020 16:31
By: plasmo on Wed, 08 April 2020 16:47
By: plasmo on Wed, 08 April 2020 16:22
By: plasmo on Thu, 09 April 2020 20:08
By: mikemac on Thu, 09 April 2020 20:58
By: mikemac on Thu, 09 April 2020 21:06
By: plasmo on Fri, 10 April 2020 06:51
By: plasmo on Fri, 10 April 2020 07:54
By: plasmo on Sat, 11 April 2020 06:55
By: plasmo on Sun, 12 April 2020 04:28
By: mikemac on Fri, 17 April 2020 21:47
By: plasmo on Tue, 16 June 2020 20:08
By: plasmo on Wed, 17 June 2020 17:47
By: plasmo on Thu, 18 June 2020 17:35
By: plasmo on Sun, 21 June 2020 19:47
By: plasmo on Wed, 24 June 2020 17:31
By: mikemac on Wed, 24 June 2020 22:37
By: mikemac on Wed, 01 July 2020 08:27
By: plasmo on Thu, 09 April 2020 20:17
By: plasmo on Thu, 02 July 2020 04:26
By: plasmo on Sun, 05 July 2020 04:20
By: plasmo on Sun, 12 July 2020 13:17
By: plasmo on Tue, 14 July 2020 18:07
By: mikemac on Wed, 15 July 2020 14:51
By: mikemac on Thu, 16 July 2020 18:03
By: Yves-D. on Wed, 08 July 2020 11:52
By: Yves-D. on Wed, 08 July 2020 11:58
By: plasmo on Thu, 09 July 2020 05:07
By: Yves-D. on Mon, 10 August 2020 04:29
By: mikemac on Mon, 10 August 2020 12:29
By: plasmo on Wed, 12 January 2022 21:12
By: plasmo on Fri, 28 January 2022 07:40
By: plasmo on Mon, 01 August 2022 03:14
By: e2k on Mon, 01 August 2022 10:58
By: plasmo on Sat, 27 August 2022 18:47
By: plasmo on Mon, 29 August 2022 19:19
By: plasmo on Mon, 12 September 2022 13:59
By: mikesmith on Tue, 13 September 2022 11:31
By: mikesmith on Tue, 13 September 2022 16:54
By: plasmo on Tue, 14 March 2023 13:30
By: plasmo on Wed, 15 March 2023 06:45
By: plasmo on Wed, 15 March 2023 17:23
By: plasmo on Thu, 30 March 2023 17:58
By: plasmo on Fri, 12 August 2022 09:33
By: plasmo on Sun, 14 August 2022 19:11
By: plasmo on Mon, 15 August 2022 19:29
By: plasmo on Tue, 16 August 2022 13:18
By: Yves-D. on Thu, 18 August 2022 23:26
By: plasmo on Sun, 21 August 2022 05:37
By: plasmo on Mon, 22 August 2022 16:24
By: e2k on Mon, 22 August 2022 23:33
By: e2k on Wed, 24 August 2022 22:53
By: plasmo on Tue, 02 August 2022 04:21
By: plasmo on Tue, 02 August 2022 14:51
By: plasmo on Wed, 03 August 2022 11:59
By: plasmo on Thu, 04 August 2022 18:37
By: plasmo on Fri, 05 August 2022 16:47
By: plasmo on Sat, 06 August 2022 17:16
By: plasmo on Mon, 08 August 2022 18:18
By: simonj5 on Wed, 10 August 2022 01:38
By: plasmo on Wed, 10 August 2022 15:20
By: plasmo on Fri, 12 August 2022 09:39
By: plasmo on Tue, 20 June 2023 11:42
Current Time: Sat Sep 27 07:45:41 PDT 2025
Total time taken to generate the page: 0.39855 seconds
