Home » RBC Forums » General Discussion » Zeta 2 and ParPortProp
Zeta 2 and ParPortProp [message #9631] Tue, 18 January 2022 00:44 Go to next message
stefanf is currently offline  stefanf
Hi there,
I've built the Zeta 2 and the ParPortProb board and both are working so far. But if I connect both with each other, the PartPortProb Board is not recognized, see picture.
I programmed the 24LC512 EEprom as in the instructions and adopted the standard templates.
Can someone help? thank you
Kind regards
Stefan F, Germany/Berlin
Re: Zeta 2 and ParPortProp [message #9635 is a reply to message #9631] Tue, 18 January 2022 23:18 Go to previous messageGo to next message
alkmar is currently offline  alkmar
I ran a ground on that too. it turned out to be the revision of firmware I programmed the ParaPort with. If I remember correctly their is a directory buried with thin the Zeta 2 distro that includes new firmware for the ParaPort. I'll take a look tomorrow and get back to you.
my symptoms were my Zeta 2 worked in every way except for it not seeing the ParaPort, the Paraport VGA output worked perfectly without getting text from the Zeta 2, and you would get the initial beep from the ParaPort pizo speaker.
Re: Zeta 2 and ParPortProp [message #9636 is a reply to message #9635] Tue, 18 January 2022 23:39 Go to previous messageGo to next message
Actually the flash file you want is from the RomWBW disto, check the \RomWBW-vxxxx-Packaege\Binaray\ParPortProp.eeprom.
https://github.com/wwarthen/RomWBW/releases
Re: Zeta 2 and ParPortProp [message #9637 is a reply to message #9636] Wed, 19 January 2022 00:32 Go to previous messageGo to next message
Hi there,
Thank you for the feedback. If I connect the ParPortProp Board to 5 volts, it works, at least the messages appear on the screen.
On the Zeta V2 Board I have the current version 3.01 in the EEprom or also the file for the 24LC512 EEprom which is on the ParPortBoard.
I've also tried older versions, always with the same result that the ParPortBrop board at address 0x60 is not recognized. I'm slowly running out of ideas as to where that might be.
Kind regards
Stefan/Germany/Berlin
Re: Zeta 2 and ParPortProp [message #9638 is a reply to message #9637] Wed, 19 January 2022 19:53 Go to previous messageGo to next message
I posted my configuration in case it may be helpful, let me know if there is any other info that would be useful.
When powered on, my Zeta V2 enumerates most of the devices within 2 seconds. At 3 seconds the Zeta V2 enumerates the ParaPortPorp and my ParaPortPorp will flash the SD drive access light and issue an audible beep.
Output from the serial (to capture it, it looks the same on VGA):
RomWBW HBIOS v3.0.1, 2020-04-04
ZETA V2 Z80 @ 8.000MHz
0 MEM W/S, 1 I/O W/S, INT MODE 2
512KB ROM, 512KB RAM
CTC: MODE=Z2 IO=0x20
UART0: IO=0x68 16550A MODE=38400,8,N,1
DSRTC: MODE=STD IO=0x70 Wed 2022-01-19 19:40:37 CHARGE=OFF
MD: UNITS=2 ROMDISK=384KB RAMDISK=384KB
FD: IO=0x30 UNITS=2
PPP: IO=0x60 F/W=0.96.0
PPPCON: 80X37 TEXT (ANSI)
PPPSD0: TYPE=SDHC BLOCKS=0x03B72400 SIZE=30436MB
Unit Device Type Capacity/Mode
Char 0 UART0: RS-232 38400,8,N,1
Char 1 PPPCON0: Terminal PropTerm,ANSI
Disk 0 MD1: RAM Disk 384KB,LBA
Disk 1 MD0: ROM Disk 384KB,LBA
Disk 2 FD0: Floppy Disk 3.5",DS/HD,CHS
Disk 3 FD1: Floppy Disk 3.5",DS/HD,CHS
Disk 4 PPPSD0: SD Card 30436MB,LBA
ZETA V2 Boot Loader
ROM: (M)onitor (C)P/M (Z)-System (F)orth (B)ASIC (T)-BASIC (P)LAY (U)SER ROM
Disk: (0)MD1 (1)MD0 (2)FD0 (3)FD1 (4)PPPSD0
Boot Selection?
Zeta v2 PCB v2.0 (8mhz) settings:
Firmware: RomWBW3.0.1 (for Zeta V2)
P1: 5V input power to computer
P2: Open
P4: Connected to ParaPortProp PCB (all pins)
P6: Connected to floppy drives
JP1: Open (sends serial data to ParaPortProp for VGA display and receives keyboard via serial)
JP2: Pin 1&2 from left shorted, pin 3 open
U17: 16.000Mhz
U18: 1.8432Mhz
U19: 8.000 Mhz
Powered from 5.1mm barrel connector
ParaPort Prop PCB v1.1 settings:
Firmware: 0.96.0
JP1: Shorted
JP2: Open
JP3: Pin 1&2 shorted (left most and center pin), pin 3 open
JP4: Shorted
JP5: Shorted
P3: Not used
P4: Not used
P5: Connected to Zeta 2 (all pins)
P1.5v: not connected
X1: 5.000mhz
[Updated on: Wed, 19 January 2022 21:39]
Re: Zeta 2 and ParPortProp [message #9640 is a reply to message #9638] Thu, 20 January 2022 02:16 Go to previous messageGo to next message
Hi there,
when switching on there is a beep, the LED of the SD card slot lights up briefly, the following appears on the monitor:
Initializing ParPortProb .... OK
Initializing KeyBoard....OK
Initializing SD card ..... OK
Initializing Serial Port ... OK
Starting PortIO cog..... OK
ParPortProp is ready!
At the bottom of the screen appears:
RomWBW ParPortProp F/W v0.96
After that there is a break and it doesn't go any further
greeting
Stefan
Re: Zeta 2 and ParPortProp [message #9646 is a reply to message #9640] Thu, 20 January 2022 10:24 Go to previous messageGo to next message
Can you confirm that JP1 on the Zeta 2 PCB does NOT have a jumper installed? If this is shorted all console output will be directed to the Zeta 2 serial port.
If JP1 is open all output will be directed to your ParaPortProp (VGA output and DIN keyboard input).
When booting the computer without the ParaPortProp attached, do you get all of the output I listed previously (aside from missing the devices related to the ParaPortProp)?
[Updated on: Thu, 20 January 2022 11:40]
Re: Zeta 2 and ParPortProp [message #9653 is a reply to message #9646] Fri, 21 January 2022 01:09 Go to previous message
Hi there,
Thanks for the feedback. Whether I plug jumper 1 or not, the behavior is the same.
This message appears on the external monitor connected to the ParPortPorp Board:
Initializing Keyboard....OK
Initializing SD card..... OK
Initializing Serial Port... OK
and when I connected a PC with terminal software to the RS232 of the ZETA 2 board, these messages:
ZETA V2 Z80 @ 8,000MHz
The ParPortProb Board is shown as not connected with the address 0X60, although it is connected.
I didn't connect a chain drive because I still don't have the chip for it.
greeting
Stefan
Previous Topic: Debugging a SBC V2-004
Next Topic: Dave (Yoda) Mehaffy's passing
Current Time: Sat Oct 11 02:50:44 PDT 2025
Total time taken to generate the page: 0.56265 seconds
