Home » RBC Forums » General Discussion » Porting CP/M 68K to a repurposed ADC Soneplex MPU board (CP/M 68K)
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3419 is a reply to message #3417] Mon, 04 September 2017 15:33 Go to previous messageGo to next message
Hi Plasmo,
I'd be interested in one of those boards.
Please let me know the details: norwestrzh at aol
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3425 is a reply to message #3419] Fri, 08 September 2017 12:49 Go to previous messageGo to next message
For those interested in playing with the repurposed SPX-MPU board running CP/M 68K in simulation, attached is the S-record of programs loaded in the repurposed SPX-MPU board. The same programs can also be loaded into EASy68K's Sim68K and execute in simulation. You will see the same results (with some limitations explained later) in simulation as you'll see with the actual hardware. However, you will have much greater visibility in the simulated environment: you can display and change the memory contents and you can single-step BIOS code. Since the disks A, B, &C are all in memory (disk A&B are read-only flash memory, disk C is a RAMdisk), the contents of disks can be displayed as memory. Simulation on my 2.4GHz PC is faster than the actual hardware running at 16MHz. For an example, the ASCII art program runs in 41 seconds in simulation vs 104 seconds on the hardware.
For people already have the actual SPX-MPU hardware, the simulated environment is still useful because if the hardware behaves unexpectly, you can run the same code in the simulated environment and compare results. Another use for the simulated environment is developing codes for the CPM-68K BIOS.
As mentioned before, there are limitation to the simulation, specifically the simulated console is a virtual console so there are no easy way to upload or download files from console to/from CPM. Kermit does not work in simulation which is a bother because currently the gkermit program can't receive binary files from CPM (it can send binary & text files to PC, and it can also receive text files from PC without problems), and I'm unable to debug that problem in simulation. Similarly, microEMACS expects the console to be a VT52 terminal and uses escape sequences to manipulate the cursor position. That doesn't work with simulated console.
This is the step-by-step instruction for simulating CP/M68K in SPX-MPU board:
1. run Sim68K (the program can be downloaded from easy68k.com)
2. in the drop-down menu under 'File', select 'Open...' and pick 'MPUBIOS.S68'
3. In the drop-down menu under 'File', select 'Open Data...' and pick 'CPM15000.s68' <--this is CPM15000.sr binary of CCP and BDOS.
4. In the drop-down menu under 'File', select 'Open Data...' and pick SIMDSKA.S68 <-- this is drive A image
5. In the drop-down menu under 'File', select 'Open Data...' and pick SIMDSKB.S68 <--this is drive B image
6. In the Registers area, change 'PC=' field to 00015000 <-- this is the start address of CPM-68K
7. Press 'run' icon (or F9). You should see the A> prompt in the console. You are now running CP/M-68K.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3434 is a reply to message #3425] Sun, 10 September 2017 14:06 Go to previous messageGo to next message
Bill --
Got your package today. It was very well padded, so the board was in excellent shape. Powered it up, and ran CP/M for a while. Everything works. Thanks.
It will take me a while to look it over more carefully, and become familiar with everything.
Any idea what the 3 position DIP switch and hex encoder (lower left corner) do?
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3435 is a reply to message #3434] Sun, 10 September 2017 17:09 Go to previous messageGo to next message
Likewise, my board arrived safely and powered up easily.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3436 is a reply to message #3435] Sun, 10 September 2017 18:51 Go to previous messageGo to next message
Roger & Gary,
I'm glad you've received the board in great shape. Did you take a look at drive C? Drive C is a RAMdrive backed up with a super capacitor. The capacitor can keep its content intact for well over a week on my bench, but I'm curious whether the anti-static bag would discharge the capacitor during shipping.
I'll answer your question about the switches directly, but it is also an action item for me to update the wiki page with better organized info regarding memory map & I/O schematics.
The hex switch and 3-pos toggle DIP switch are buffered via UG2 (HC244) and appear as a memory location as follow:
DIP SW1 is d0, with 10k pull up,
DIP SW2 is d1, with 10k pull up,
DIP SW3 is d2, with 10k pull up,
d3 is pulled up with 10K,
Hex switch SK3 pin 1 to d4, with 10K pull up,
Hex switch SK3 pin 4 to d5, with 10K pull up,
Hex switch SK3 pin 3 to d6, with 10K pull up,
Hex switch SK3 pin 6 to d7, with 10K pull up,
Note: the 4-bit input value for SK3, d4-d7, is invert of the value printed on the switch.
Attached is a hand-sketched schematic of the switches (You can see the envelop glue lines because it was literally on the back of an envelop).
index.php?t=getfile&id=594&private=0
For completeness sake, the high byte of the discrete inputs are buffered through UG11 (HC244) & UG3 as follow:
d8 is 96-pin DIN pin B27 pulled up with 10K, 10K series resistor to UG11,
d9 is 96-pin DIN pin A27 pulled up with 10K, 10K series resistor to UG11,
d10 is 96-pin DIN pin B28 pulled up with 10K, 10K series resistor to UG11,
d11 is 96-pin DIN pin A28 pulled up with 10K, 10K series resistor to UG11,
d12 is 96-pin DIN pin B29 pulled up with 10K, 10K series resistor to UG3,
d13 is 96-pin DIN pin A29 pulled up with 10K, 10K series resistor to UG3,
d14 is 96-pin DIN pin B30 pulled up with 10K, 10K series resistor to UG3,
d15 is 96-pin DIN pin A30 pulled up with 10K, 10K series resistor to UG3,
The memory map of the I/O resources is as follow:
0x300000-0x30001F, 82C55
0x300020-0x30003F, 68692 DUART
0x300040-0x30005F, real time clock, RTC72423 <- backed up with super capacitor
0x300060-0x30007F, switch inputs <- this is the hex switch/DIP switch/DIN connector
0x300080-0x30009F, special function, still need to figure it out.
The connection of the DB25 connector on the face plate:
DB25-2 RX buffered via UH12 to 68692-35 (RxDA)
DB25-3 TX buffered via UH12 to 68692-33 (TXDA)
DB25-5 RTS buffered via UH12 to 68692-32 (OP0)
DB25-4 CTS buffered via UH12 to 68692-42 (IP5) & 68692-8 (IP0) <- these are engineering changes, the blue wire on 68692 and a long blue wire at the back of the board.
You may also be interested in the pin definition of the 96-pin DIN connector. I attached a text file below. It needs to be clean up and included in the wiki, but it is information you and other users (there are 5 users right now) of this board may want to have now.
  • Attachment: ug2-sch_F.jpg
    (Size: 905.83KB, Downloaded 3610 times)
  • Attachment: Din96.txt
    (Size: 4.15KB, Downloaded 604 times)
[Updated on: Sun, 10 September 2017 19:00]
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3437 is a reply to message #3436] Sun, 10 September 2017 19:10 Go to previous messageGo to next message
The fact there are 7 user definable switch inputs and 8 inputs from DIN connector is quite useful. The software can change mode based on the switch inputs. When I add the Compactflash IDE daughter board I will take one of the DIN discrete input and tell the BIOS that external IDE-CF is attached so to enable CF drives.
In my XBEE application, I use the hex switch to assign address of each XBEE station and the DIP switches for different modes of operation.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3439 is a reply to message #3437] Mon, 11 September 2017 10:26 Go to previous messageGo to next message
Drive C: on my board looks thus:
A>dir c:
C: AS68SYMB DAT : CONC SUB : CLINKONC SUB : BASIC SUB : BLINK SUB
C: ME 68K : ASM SUB : HELLO C : HELLO 68K : HELLO O
C: ASCIIART BAS : ASCIIART 68K : ASCIIART O : FCOMP S : FCOMP O
C: FCOMP 68K
I think that's OK? I wondered about the anti-static bag as well. Seemed not to have drained my super cap.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3440 is a reply to message #3439] Mon, 11 September 2017 10:41 Go to previous messageGo to next message
Roger,
These files look good. They were used or created to check out the board and software on drive A & B.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3450 is a reply to message #3417] Wed, 13 September 2017 11:13 Go to previous messageGo to next message
Yes I'm interested in one to play with - what would shipping to the UK be like ?
On the IDE performance by way of comparison a 4MHz Z80 driving an SD card via a hardware SPI interface (bytewise so it just does INI INI INI INI INI INI ......Wink comes out at a similar speed to the 33MHz Z180 bit banging it which shows the value of having hardware to do the job Cool. For IDE you should be able to read 16bits/instruction and you can run most CF cards at PIO4 if you negotiate the speed with it. That's supposed to top out at 16MB/second (120ns cycle time) which should be adequate for any retro hardware Cool
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3452 is a reply to message #3450] Wed, 13 September 2017 17:56 Go to previous messageGo to next message
etchedpixels,
Thank you for your interest in the repurposed SPX-MPU board for CPM-68K. I have not shipped package internationally for quite a while. According to the US Postal Service, First Class International to UK is $22.50. I need your postal code in UK to get a accurate quote from UPS, and if you have a preferred carrier, I'd happy to use it.
The board does have a 16-bit interface to IDE via the 82C55. To read a CF sector of data (512 bytes), the processor needs to:
1. assert nCS, IDE data register (addr 0x0) lines on 82C55 port C,
2. assert DIOR line (82C55 port C),
3. read in low byte IDE data (82C55 port B),
4. read in high byte IDE data (82C55 port A),
5. negate DIOR line.
Repeat steps 1-5 256 times to read a CF sector. I measure 8.6uS to do step 1-5, so the max transfer rate is 230k byte/sec.
Edit: Looking at the code again, I can optimize by using address pointers and movep instruction. So the loop time is reduced to 3.1uS for an effective transfer bandwidth of 650k bytes/sec
[Updated on: Wed, 13 September 2017 18:23]
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3453 is a reply to message #3452] Thu, 14 September 2017 04:17 Go to previous messageGo to next message
Wouldn't it be faster to use the IDE in 8 bit mode? saves on (slow) CPU overhead.
Rienk
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3458 is a reply to message #3453] Thu, 14 September 2017 19:02 Go to previous messageGo to next message
The reason IDE access thru 82C55 is slow is because the processor needs to manually wiggle the controls and address lines of IDE which are connected to 82C55's port C. It is the same number of instruction to wiggle addresses/controls for 8-bit mode as for the 16-bit mode. Having invested in the same number of instructions to wiggle the addresses&controls, I might as well read 16-bit of data instead of 8-bit.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3551 is a reply to message #3458] Fri, 29 September 2017 12:06 Go to previous messageGo to next message
Spent this morning looking over the SPX-MPU boards that were recently purchased from eBay which only have 29F010 flashes (e.g., http://www.ebay.com/itm/122306457847 Wink. I determined they have the same pc board layout as my collection of boards that have two banks of 29F040. So it is possible to switch out the 29F010 with 29F040.
I also have plenty of the SPX-MPU board with 2 banks of 29F040 already installed so anyone interested in running CPM-68K or just want to have a general 68000 development board with 1 meg or RAM, 2.25 meg of flash and plenty of peripherals for $20 (plus $5 shipping in USA) please contact me.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3575 is a reply to message #3551] Wed, 04 October 2017 09:09 Go to previous messageGo to next message
I guess the 29F010 is sufficient anyway once you have the IDE or SD interface available ?
(I went digging - the difference comes from the boards and their original OS - at some point the OS update on the cards stopped fitting and they introduced a new/upgraded board requirement. Wink
[Updated on: Wed, 04 October 2017 09:09]
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3577 is a reply to message #3575] Wed, 04 October 2017 11:52 Go to previous messageGo to next message
You are right that CPM68K can run on the repurposed SPX-MPU board with just the boot flash (256K bytes) and an expansion daughter board containing an IDE or SD drive. Currently the monitor and the CPM image (including BIOS) are reside in the boot flash with plenty of room for growth. The 2nd & 3rd bank of flash (2megabyte total) contain disk images, but that can be relocated to the CF or SD cards. My original motivation is to have a low cost working CPM68K all in a single PC board, but expansion boards with IDE-CF and other hardware will certainly add significantly more flexibility and features to the base board. It is desirable to have a runtime configurable BIOS that detects the system parameters and enable the appropriate drivers, which dovetailed nicely with the current discussion on modular CP/M BIOS.
While digging into SPX-MPU, have you run across hardware design documents with schematics and/or theory of operation? What about a way to upgrade software? I used a brute-force hardware programming header to "hijack" the boot flash and overwritten the factory code, but it is so much easier to reprogram using existing software if such capability exists.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3588 is a reply to message #3577] Tue, 10 October 2017 05:39 Go to previous messageGo to next message
I found nothing about theory of operation or schematics, not even the pinouts. There *is* a remote update facility on the cards but there's nothing helpful in the documentation. The manuals dated around 2000 show a system where you connect to the board either via serial or over a network and trigger an ftp from an internet host for the firmware (which by then at least is vxWorks) so presumably you'd need a fully functional soneplex to do so, although there is a reference elsewhere to xmodem.
And by way of other hits
https://www.linkedin.com/in/eric-nelson-525ab96a
seems to be one of the folks who worked on it - and this also confirms the 68000 stuff was in the market in 2000
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3625 is a reply to message #3588] Mon, 16 October 2017 21:42 Go to previous messageGo to next message
Received the pc board from Seeed Studio this morning. Here is the assembled board and how it plugs into the SPX-MPU board. It appears to be working. The updated BIOS adds 4x 8-megabyte CF drives, D:, E:, F:, G:, to the existing flash drives A:, B: and ramdrive C:. I will update the wiki page with the design files.
index.php?t=getfile&id=620&private=0
index.php?t=getfile&id=621&private=0
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3841 is a reply to message #3625] Sat, 25 November 2017 06:55 Go to previous messageGo to next message
I completed the manual tracing of the pc board and updated the SPX-MPU schematics in the wiki page:
https://www.retrobrewcomputers.org/doku.php?id=builderpages: plasmo:spx-mpu:mpuschematic
It is likely the schematics contain errors. Please let me know if you've found them.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3874 is a reply to message #3841] Wed, 29 November 2017 15:39 Go to previous messageGo to next message
The wiki page for the CF IDE daughterboard is completed. https://www.retrobrewcomputers.org/doku.php?id=boards:other: idecf2din:start
The daughterboard works very well. I encountered no problems with different brands of CF. Four additional 8-meg disks are added with the daughterboard so a MPU302 with the daughter board will have 7 disks: drive A and B are flashdisks, drive C is the RAM disk, drive D to G are the additional CF disks on the daughterboard. The current owners of MPU302 need to update their BIOS to accommodate the daughterboard. The updated BIOS will detect the presence of daughterboard and adjust the number of CF disks accordingly. The BIOS update procedure is documented in the MPU302 wiki:
https://www.retrobrewcomputers.org/doku.php?id=boards:sbc:mp u302:mpu302updates
At this moment I have 6 bare CF IDE daughterboards. If you are interested in bare PCB, it is $1.50 plus $1.50 for shipping in the USA. For assembled and tested board, it is $8 plus $3 shipping in the USA.
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #3995 is a reply to message #3874] Fri, 22 December 2017 10:01 Go to previous messageGo to next message
A number of forum members have purchased the MPU302 (AKA repurposed SPX-MPU board), I thought it maybe useful to document the frequently asked questions here.
wiki page for MPU302 is here:
Powering up: If you have the CF daughterboard/MPU302 combo, you MUST power up via the 2.5mm power jack on the daughterboard (center lead is 5V, barrel is ground). This is because the 5V is shorted to ground when 2.5mm power plug is not inserted. Expected power consumption is 300mA @ 5V
Serial port connection: Terminal program should be configured to 38400 baud, N,8,1, with RTS/CTS hardware handshake. The serial port voltage level is RS232, not TTL, so it won't work with the cheap serial-to-USB adapters with TTL level I/O. A DB25 to DB9 (assuming serial port cable out of the PC is DB9) is needed with the following wiring:
DB9       DB25
2---------3
3---------2
7---------4
8---------5
5---------7
As many MPU302 I've plugged/unplugged, I find the DB25 connector difficult to unplug, so I actually used the pigtail kludge in the picture on my bench.
Boot to CP/M-68K:
When power is applied initially, the MPU302 will sign on with:
AMBug v2.07aHardware handshake with CTS/RTS, 8/30/2017
RAM at $0 and alias at $200000, boot ROM at $600000. Type "he" for help
Type 'bo' to boot into CP/M-68K <--This is obscure because 'bo' command is not shown in the 'help' menu. I'll fix that in next revision.
[Updated on: Fri, 22 December 2017 10:16]
Re: Porting CP/M 68K to a repurposed ADC Soneplex MPU board [message #4704 is a reply to message #3306] Sun, 13 May 2018 03:52 Go to previous message
norwestrzh wrote on Sat, 05 August 2017 10:18
Hmmm .....
MBASIC(interpreter) (Z80 @ 10 MHz) 1:54
MBASIC(interpreter) (FPGA Z80 :46 (equiv. to ~25 MHz)]
CB68(compiled) (68k @ 6 MHz) 4:23 <== I can get it to work on one of my slower 68ks
EhBASIC(interpreter) (68k @ 12 MHz) 0:55
EhBASIC(interpreter) (CP/M 68k @ 12 MHz) 1:26
EhBASIC(interpreter) (68k @ 10 MHz) 1:06
EhBASIC(interpreter) (68010 @ 10 MHz) 1:02
EhBASIC(interpreter) (8-bit strapped 68EC00 @ 10MHz) 2:55
GCC(compiler) (68k @ 12 MHz) 0:20
asciiart.bas benchmark for Rienk's sbc-2g-512 7.3728Mhz Z80 board running NASCOM ROM BASIC Ver 4.7:
2m43s
10 FOR Y=-12 TO 12
20 FOR X=-39 TO 39
30 CA=X*0.0458
40 CB= Y*0.08333
50 A=CA
60 B=CB
70 FOR I=0 TO 15
80 T=A*A-B*B+CA
90 B=2*A*B+CB
100 A=T
110 IF (A*A+B*B)>4 THEN GOTO 200
120 NEXT I
130 PRINT " ";
140 GOTO 210
200 IF I>9 THEN I=I+7
205 PRINT CHR$(48+I);
210 NEXT X
220 PRINT
230 NEXT Y
Ok
run
000000011111111111111111122222233347E7AB322222111100000000000000000000000000000
000001111111111111111122222222333557BF75433222211111000000000000000000000000000
000111111111111111112222222233445C      643332222111110000000000000000000000000
011111111111111111222222233444556C      654433332211111100000000000000000000000
11111111111111112222233346 D978 BCF    DF9 6556F4221111110000000000000000000000
111111111111122223333334469                 D   6322111111000000000000000000000
1111111111222333333334457DB                    85332111111100000000000000000000
11111122234B744444455556A                      96532211111110000000000000000000
122222233347BAA7AB776679                         A32211111110000000000000000000
2222233334567        9A                         A532221111111000000000000000000
222333346679                                    9432221111111000000000000000000
234445568  F                                   B5432221111111000000000000000000
                                              864332221111111000000000000000000
Smile
[Updated on: Sun, 13 May 2018 03:54]
Previous Topic: Any ParPortProp PCB's available?
Next Topic: ROMSIMM for Macintosh SE/30 aficionado
Current Time: Sat Oct 11 21:35:39 PDT 2025
Total time taken to generate the page: 0.03908 seconds
